10-06-2012, 11:52 AM | #1 |
Drives: 2011 5.7L Tundra Double-Cab X-SP Join Date: Mar 2012
Well this isn't good...
Long story short, 3 blue LEDs in my driver side fog halo have shorted/burned out. The RGB LEDs are tri-chip and the red and green work fine. I usually run my halos dark orange or amber so it's not really a big deal, but now when I use any color that mixes with blue it looks horrible.
Now I'll have to get a new ring, remove the housing, cut it open, re-set the ring, wire/seal everything back to normal, and then re-install.... They have been on my car for several months and I use them about an hour a day average. I posted my video on 6/25 and lets say they went bad 9/25. That puts about 90 hours on them. Not quite what I expected but what can you do... (Photos soon) Last edited by awfarley; 10-07-2012 at 11:27 PM. |
10-06-2012, 12:24 PM | #2 |
Drives: 2010 Black LS Join Date: Jul 2010
I had the same problem with my head light halos except the red went out in 3 LED's in like a month, still haven't gotten around to fixing them
10-06-2012, 12:26 PM | #3 |
Drives: 2016 Camaro 2ss Join Date: Aug 2010
whoa that sucks big time for you guys. My white halos are still going strong. (Knock on wood)
10-06-2012, 01:19 PM | #4 |
Im not sure what I'll do when I take them out. I've thought about an HID kit. I've heard they melt the housing or lens but mine is glass. I doubt I'll go back with halos in them.
10-06-2012, 01:37 PM | #5 |
HID's melt the housing? never heard of that . I know i have a projector retrofitted it in mine and its still doesnt melt. And believe me its gets pretty hot.
10-06-2012, 01:45 PM | #6 |
I'm talking about the foglight housing. I've seen at least two threads on here. Your foglights are retro'ed HID?
10-06-2012, 02:17 PM | #7 |
no there not lol. Maybe next time ill read better
10-06-2012, 02:35 PM | #8 |
10-07-2012, 11:27 PM | #9 |
Updated with pictures :(
10-07-2012, 11:34 PM | #10 |
Drives: 2012 Camaro LT Join Date: May 2012
If it's the resistors that went bad, Flashtech just released their v2's which I'm fixing to go with on my retrofit. The v2's have the resistors mounted to a seperate box rather than behind the ring as with the previous model. Just food for thought.
10-07-2012, 11:40 PM | #11 |
Yeah I was hoping for that but I thought if the resistor went bad it would cause the entire LED to fail and not just the blue chip. I could be wrong though.
10-22-2012, 10:12 AM | #12 |
Drives: Delorean Join Date: Apr 2012
Farley. That is 100% under warranty my friend. We can swap that out for you. And if you want to upgrade to the Fusion v2 halos with external resistors I can work you out a sweet deal my friend.
