06-13-2009, 01:14 AM | #1 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
PlanetLSX.com 2010 Camaro SS Baseline Track Results
Details:
2010 Camaro SS/RS (2SS) Link to pics 6-speed manual 100% showroom stock down to the 37 psi air in the rear tires. I mean 100% stock. No weight removed, as-purchased. 1,200 miles on the car (2 weeks old) 4,045 lbs raceweight (half tank, and I'm 190 lbs) Holding RPM between 3500-4000 and slipping clutch out on launch. Powershifting (no lifting throttle between shifts) at red line (6K-6.2K) Coolant temps 212-218F Density Altitude was +2,301 ft (it was 96F earlier today, 88 for these passes) Three consecutive passes (hot lapped): 13.256 @ 108.43 (2.098 60') 13.194 @ 109.62 (2.128 60') 13.070 @ 109.07 (2.057 60') Videos will be posted later this weekend. If I can just get a 1.9X 60' time, it will go 12s in the heat. Imagine what it would run in negative density altitude! Probably 12.70s... I may try to go back to the track on Sunday to get a 12! Tony
Fquick.com/NineBall
06-13-2009, 01:30 AM | #2 |
Drives: on order black 2010 2ss Join Date: Mar 2009
not bad
06-13-2009, 01:34 AM | #3 |
Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
Holy crap. That is pretty damn amazing for stock.
Ive said time and time again all it takes is a good driver and itll be in 12s stock. |
06-13-2009, 02:14 AM | #4 |
Good job Tony!
06-13-2009, 07:13 AM | #5 | |
06-13-2009, 12:18 PM | #6 |
Drives: 2010 Hyundai Genesis Coupe 2.0T Join Date: Dec 2008
Yeah, using the DA calculator it says you'd be running 12.7. Very impressive.
06-13-2009, 12:31 PM | #7 |
Nice
06-13-2009, 04:17 PM | #8 |
Stock rev limiter is 6600? My tach show redline at 6200 or so. I don't run it up to the limiter, it stops pulling after 6200 anyways. Just 3 gears used.
Fquick.com/NineBall
06-13-2009, 04:31 PM | #9 | |
http://www.camaro5.com/forums/showthread.php?t=24556
06-13-2009, 04:56 PM | #10 |
Drives: Hyundai Sonata Join Date: Feb 2009
The stock fuel cutoff is 6600. Redline is a little lower.
06-13-2009, 04:58 PM | #11 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
Tony-- what were your 1/8th mile splits and mph?
06-13-2009, 05:00 PM | #12 | |
Drives: VStar 1100 Classic, 2010 CGM 2SS/RS Join Date: Mar 2009
Good job!
06-13-2009, 05:29 PM | #13 |
Drives: 2010 Camaro Join Date: Jul 2008
NICE!!!! great info!!!
You running 93 octane??? |
06-13-2009, 06:14 PM | #14 |
Joelster, on my 13.07 pass, the 1/8 mile was 8.512 @ 85.13 mph.
Scooter, yes on the 93 octane pump gas. I'm going to have to play with the shift points a little, I figured they were about 200 rpm past redline, like most GM cars. That was where I shifted, at redline.
Fquick.com/NineBall
Similar Threads | ||||
Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
Track Results are in for 2010 CAMARO SS w/ cold air intake & ecu tune!! | Late Model Racecraft | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 45 | 05-14-2009 07:23 PM |
2010 Camaro, Decisions Decisions… (Winding Road Review) | Xmicro_SS | 5th Gen Camaro SS LS LT General Discussions | 19 | 05-09-2009 11:40 AM |
