Old 05-10-2013, 11:22 AM   #1
CamaroIOM12
Jim
CamaroIOM12's Avatar
Drives: 2013 2SS Camaro Convertible
Resonated X pipe???
I have a CAI with the air scoop and the water bottle is relocated, just put on MRT V2 axle backs. Might be a stupid question but what does a resonated X pipe do???
CamaroIOM12 is offline   Reply With Quote
Old 05-10-2013, 01:12 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
An X pipe will replace the factory H pipe. The benefit of an X pipe over an H pipe, is the X pipe will provide better scavenging. Basically, as every pulse of the exhaust passes through the X it creates a vacuum to help pull the next pulse from the other side of the X. This helps the engine breath easier and more efficiently.
The resonated X is essentially a perforated X pipe with a muffler surrounding it. They will quiet down the exhaust and reduce rasp.
Please feel free to call, PM or email me anytime with questions. We offer anything and everything Magnaflow at unbeatable prices.
Best regards,
Tyler
888-308-6007
Old 05-10-2013, 01:18 PM   #3
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Obviously, headers are not a concern/possibility for LFX-equipped cars, so I might modify the statement to say that it's a good idea to consider a resonated x-pipe for any V-6 exhaust redo.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-10-2013, 01:20 PM   #4
Niko
Treasure Coast Camaro 5
Niko's Avatar
Drives: Black Camaro LFX
The resonated X is essentially a perforated X pipe with a muffler surrounding it. They will quiet down the exhaust, but in my opinion it is a necessity on the V6 if you have/planning on getting headers.
Best regards,
Tyler
888-308-6007
If that's the case just a regular x pipe would work with the LFX engines because our headers are built into the engine right. Will a regular x pipe quiet the exhaust as well?
Niko is offline   Reply With Quote
Old 05-10-2013, 01:43 PM   #5
JohnnyBfromPeoria
Nope.
John B.
Old 05-10-2013, 02:58 PM   #6
JDP Sales
JDP Sales's Avatar
John B.
Good call.
It will change the exhaust note but not by much.
Best regards,
Tyler
888-308-6007
Old 05-10-2013, 07:07 PM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The use of the resonated x-pipe you are seeing is to help get rid of the drone with the MRT v2. It is pretty effective if you find the drone annoying but it will make the exhaust a bit quieter.
Old 05-10-2013, 08:59 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
It's 100% needed if you have any after market exhaust.
Mods:
Old 05-13-2013, 07:56 AM   #9
CamaroIOM12
Jim
Thanks for all the knowledge!!
Old 05-13-2013, 10:33 AM   #10
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
But you dont have to go Resonated if u dont want to, i went Magnaflow TruX instead..easier to fit and sounds good without being obnoxious.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 05-13-2013, 10:43 AM   #11
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Did going TruX introduce any more rasp or drone or did it actually take some away?
Old 05-13-2013, 02:00 PM   #12
IneedAZ
IneedAZ's Avatar
No rasp at all...i think it sounds good. I have Solo HFC that i installed at the same time as Tru X. Then running an Axle Back Dynomax VT system. I still have the factory resonator after the X pipe. At some point i may eliminate it, but for now no complaints.
Old 05-13-2013, 06:09 PM   #13
Abstrak
Abstrak's Avatar
Drives: 2012 AGM Camaro LS / Team LFX
I have had the car a year and still cant decide on an exhaust system listening online doesnt help and most of the 6s in my area arent modded at all. hell most of the v8s arent modded either except for select few guys that meet up on the weekends.
Abstrak is offline   Reply With Quote
