Old 06-29-2009, 10:19 AM   #1
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
Drives: Victory Red 2010 2SS/RS A6
Passenger Side Air Leak or Side Mirror?
Is anyone hearing an air leak on the passenger side? At first I thought it was a leak in the window molding BUT while driving, my wife rolled down the widow and you could still hear it. She put her hand on the side mirror and the noise disappeared.
This happen to anyone else and if so, what did you do to fix it?
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected)
Icntdrv55 is offline   Reply With Quote
Old 06-29-2009, 08:41 PM   #2
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Yeah, I think the air going over the mirrors makes a funny whistling noise, if that's what you're talking about. I hear it when I put the window down.
jachevy28 is offline   Reply With Quote
Old 06-30-2009, 11:57 AM   #3
Cheshirelaugh
Cheshirelaugh's Avatar
Drives: 2010 SIM Camaro
I've heard this too, assumed (hoped) it was just a whistle effect from the mirror. Haven't paid attention to what speeds I was doing when it starts/stops.
Also, another possibility (I really haven't looked into it close enough)... My on my old 91 Grand Prix, when the windows were down the seat-belt hinge/pully...thing up above the driver's left shoulder would whistle... Maybe it's something like that. Just throwing that out there as a thought.
2G1FT1EW7A9109480
2SS/RS SIM w/ Sunroof
Ordered 10/13
Built 5/15
Delivered 6/19
Picked-up 6/22
Cheshirelaugh is offline   Reply With Quote
Old 06-30-2009, 08:36 PM   #4
Lloyd LeBaron
Drives: 1985 irocz
no sound problems on my end.
Lloyd LeBaron is offline   Reply With Quote
Old 07-01-2009, 02:44 AM   #5
Vash
Drives: 00 Blazer
A leak or a sound?
Old 07-02-2009, 11:44 AM   #6
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
first thought it was a leak in the window after rolling the window down, you can still hear it. Put your hand on the side mirror and it stops!
Old 07-02-2009, 05:28 PM   #7
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Check your DIC tire pressures...a leak that loud will definately register low pressure.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 10-21-2009, 09:22 PM   #8
Atcer
Atcer's Avatar
Drives: 2LT RS Silver Ice w/Cyber Grey strp
I have the same issue but on the drivers side. take a flash light and lookdown into the window channel behind the tweeter if you see the triangle molding will have a gap from the glass, if your other side is not makeing noise compare the same points with the light and you will notice the weather stripping is not sealed to the glass and was deformed when the door panel was installed. Mine has since been replaced and noise free. You can also push in the weather stripping behind the speaker and it will go away for a second or two.
Atcer is offline   Reply With Quote
Side air vents / gills ?? steviefranchize Cosmetics and Lighting Modification Discussions 13 05-26-2009 12:55 AM
Damaged Side Mirror..aka Another Use for Duct Tape Tigerrag24 5th Gen Camaro SS LS LT General Discussions 28 05-05-2009 11:08 PM
side mirror question camarofanatic Cosmetics and Lighting Modification Discussions 2 11-11-2008 06:40 PM
Passenger side. Jamestwilliams Cosmetics and Lighting Modification Discussions 0 08-29-2008 08:43 PM
