| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
MJ is finally home!
Drives: 2010 CGM 2SS/RS Camaro M6 Join Date: Jan 2009
So we get stuck with low end Tremec?
Looking around for more information about the Tremec TR-6060 tranny, I came across a GM link with info about the different types of tremecs. Basically the tremec in the Camaro is only rated for 430 lb -ft. of torque. All along I assumed it was 600 lb ft. according to the Camaro5 wiki.
![]() I know its a cost cutting measure, but leaving only a 10 lb ft. torque difference in the specifications? Gm Link - http://media.gm.com/us/powertrain/en..._MG9_M10_n.doc Low maintenance The TR6060 6-speed uses Texaco ATF Type III 1863 fluid and is certified "fill-for-life," requiring no fluid changes. The clutch is activated hydraulically, which automatically compensates for clutch disc wear, eliminating manual adjustments (except for the ZR1 which uses a traditional clutch). The Tremec TR6060 six-speed has evolved from a design that aimed to require virtually no maintenance in all but the most severe conditions. Overview Both the standard Corvette and the high-performance Z06 use the TR6060 designated as MM6, which is validated to 500 lb-ft of torque, while the TR6060 with the Z51 option features higher ratios and is designated as MZ6. It is validated to 430 lb-ft of torque. The ultra high performance ZR1 uses the TR6060 designated as the MH3, which is validated to 650 lb-ft of torque. The CTSv uses the MG9 version of the TR6060 validated to 560 lb-ft of torque. The Camaro uses the M10 gear set validated to 430 lb-ft |
Inform the men.
Drives: 78LT,94Z,86,08Silverado,98F150 Join Date: Sep 2006
doesnt say that it broke at that power, just that its capable of holding that power... which is roughly what the LS3 puts out... isnt it?
you are reading too much into it. how much power does the Z06 make? ~500hp.... the ZR1 makes around 650hp.... CTSv makes around 550hp.... do you think GM is going to put a transmission in there that can juuuuuuuuuuuuust barely support the existing power of the motor?
#3 | |
Happy Thanksgiving
Drives: 2010 Black SS/RS M6 Join Date: Mar 2009
2010 Black 2SS SS/RS LS3 M6 R6P
Vin#:3934 ![]() |
#4 | |
![]() ![]() ![]() ![]() Drives: Tundra Join Date: Sep 2008
#5 | |
![]() ![]() ![]() ![]() Drives: 2003 Cobra Convertible Join Date: Feb 2009
That being said, the CTSV's TR6060 probably does have some noticeably upgraded internals that makes it differ from the base vettes and camaro's.
![]() 2003 Mustang Cobra Convert 453rwhp / 464rwtq 1968 Galaxy 500 Conv - 533ci solid roller BBF :bowdown: |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ... Join Date: Oct 2008
Gee..........I'm getting an automatic.........I guess I'm just nosey tonight or bored.
#7 | |
What does "is" mean?
Drives: 02 Silverado, 09 Vue, 10 1SS Join Date: Aug 2008
Also, what a part is rated at and what it takes to break it are completely different numbers. Continuous load, peak load, and shear strength are just three of those ratings. The number you're looking at is continuous load. There is a safety margin built in for manufacturing tolerance also. My degree is in electronics, but I dabble in mechanical.
Come ON 2012! |
#8 | |
![]() ![]() ![]() Drives: 1968 LS2 powered - Bad Penny Join Date: Jun 2009
Don't get your tech from any Wiki page.. it's only as good as the person writing it. lol I have two TR-6060 varients in my shop and I'm currently working with Tremec on a tech story explaining the difference between the TR-6060 (T56 Magnum) and the T56... Being rated in the 400s is nonsense and the person that wrote that isn't very well informed.
Tech Editor for Camaro Performers Magazine
1968 Camaro - LS2, stuff, called Bad Penny 1968 Camaro - In progress, called Track Rat 2010 Camaro - Just arrived www.fquick.com/steve1968ls2 |
#9 | |
Then again, on street tires you could run 1000 hp though the trans since it will never hook. Hard shocks is what kills transmissions. The main differences between the various TR6060 varients is in gearing and in the front case/tail shaft areas. Acutally most have the same gearing except the ZR1 which has a very close ratio setup. I will talking with the Tremec guy all next week.. what questions do you want me to ask?
#10 | |
Oh, and I assume that the different variants all use the same housing, shaft design, bearing support locations, etc., so what (besides ratios) really changes depending on application? Do they use higher grade steel for the higher hp cars?
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy |
#11 |
has various muscles
I would hope not but given the 10 bolt rear end in the previous generation, it wouldn't be totally unthinkable.
#12 | |
Since the TR6060 uses a remote shifter system that's the biggest change.. and of course there would be differences base on whether the target car is IRS or live axle. I have the aftermarket version (called a T56 Magnum) in my orange '68 Camaro. The big diff there is that it has a direct (more traditional) shifter, but the internals are identical to the OEM version. I will ask them next week about differences in internals.. but I'm pretty sure they are the same from a strength standpoint.
#13 | |
It's not GM's responsibility to over-engineer parts so that people can run slicks, add blowers, or do other changes to the car. I found it fascinating that someone would add slicks, toss on a 200 shot of nitrous and then complain that the "crappy" rear blew apart. lol
#14 | |
has various muscles
I understand not having to engineer stock parts for people with FI, nitrous, etc in mind, but SLICKS? Come on now, there are countless horror stories on ls1tech about people blowing up their rear ends on sticky tires and STOCK POWER. There are also a few about DONUTS on street tires killing 10 bolts. The way I see it, durability involves the purposeful over engineering of a wear item. The fourth gen wasn't an economy commuter car - why would they design a rear end that could juuuuust barely handle 300-350hp on street tires?
#15 | ||
Inform the men.
but looking at it from GM's pov at the time, it was a cheap and easy rear to throw in the car that would not be destroyed by 90% of the buyers for the car. Quote:
axle flex is a bitch. but you dont hear about the numerous people who HAVENT blown their rears. also, how many miles are on the rears of the cars getting the rear blown over on tech? how many passes down the track?
#16 |
![]() ![]() Drives: Camaro Join Date: Oct 2008
If you were GM, or Tremec, what incentive would you have to rate the trans above the maximum HP of the car? Now, if you add an sc or other mods, they just say the trans was not rated for that HP to get out of warranting the repair.
#17 | |
has various muscles
That being said, age and mileage can be a factor, but I was in highschool (graduated '99) when the fourth gens were new and I heard about rear end problems then. ...I say "heard about" because I was still walking to school. With zero ladies. I was pretty metal.
#18 |
![]() Drives: . Join Date: May 2008
These trannies are fine. The only thing I've been told by guys in the know is not to power shift them while the rear tires are spinning.
"Going forward, I have three priorities for the new GM: customers, cars and culture. I list “customers” first because they are our top priority. For some time now, we haven’t been as focused on this simple point as we should have been. Now, we’re going to be obsessed with it - because if we don’t get this right, we don’t get to do anything else. It’s that simple." - Fritz Henderson, General Motors CEO |
#19 |
Agreed. Don't believe us? Search Trannies on Google.
Come ON 2012! |
#20 |
has various muscles
#21 | |
The death knel is if you do a first gear burnout and then, while the car is stationary, you shift to second. That little deal is VERY hard on the tranny. I was told to just start in second if you HAVE to do this. Second just can't take that hit.. It's different if the car is moving.. We road raced and autocrossed a 2010 a couple of weeks ago and the trans work flawlessly.
#22 | |
Hey, they were the weak links in the chain, but again, it's not GMs job to make the car stand up to drag racing and certainly not doing donuts.. lol It's the same reason they didn't come painted (and thus rusted).. because it saved GM a few bucks and let them give you Corvette performance at Camaro prices.
#23 | |
has various muscles
#24 | ||
Inform the men.
#25 | |
![]() I have a 2010 in my garage right now.. it's mine to mod for four months. After spending some time behind the wheel I really like it. Good solid performer. I can't wait to start modding it. And it did real well against other cars at the road track and autocross.
| Thread Tools | |
| Anybody Spray'n their SS yet - nitrous ? | WeeZee | Forced Induction - V8 and V6 | 36 | 08-16-2009 02:14 AM |
| Low Vin Number | fever_08 | Camaro Price | Ordering | Tracking | Dealers Discussions | 28 | 07-26-2009 02:06 AM |
| Front end noise | Chevy Jim | Wheel / Tires Talk | 2 | 07-01-2009 04:12 PM |
| Nitrous System ?????s | PoleCat2SSRS2010 | Forced Induction - V8 and V6 | 20 | 04-18-2009 05:57 PM |
| Gear for rear end | a6pk2go | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 10-28-2008 11:29 PM |
