Old 12-19-2013, 06:31 AM   #1
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
2013 ZL1 steering wheel removal?
Does anyone know how to remove the steering wheel off a 2013 ZL1? I'm having troubles and can't seam to get it off. I don't see the small holes on the back like earlier models? What am I missing, thanks.
Bill
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 12-19-2013, 11:46 AM   #2
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
ok there is 2 small holes. you have to turn the steering wheel 180 degrees and you will find 2 small slots that you have to get a small flathead screwdriver. and if the hole is in the left push to the right, and the hole in the right push to the left. All while you are puling the airbag out. Please also a HUGE REMINDER. DISCONNECT THE BATTERY and let the car discharge for at least 10 minutes.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 12-19-2013, 11:51 AM   #3
rgrmoreira13
I will take pics of the 2 small holes. These are the same as to all Camaro's 2012 and up
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 12-23-2013, 06:44 PM   #4
OVERPAR73
OVERPAR73's Avatar
I tried and tried but can't get the airbag to release. It's really pissing me off! I don't want to get to rough with it and damage it. I'm wanting to paint my surround. Would it hurt to drive the car without the airbag installed besides a safety issue? I was thinking about having the dealership remove the airbag this spring and come back home to remove my surround and get it painted. I would have no problem installing the airbag after I was all done with everything, of course with the battery disconnected! Any suggestions? Thanks.
Old 12-29-2013, 06:49 PM   #5
OVERPAR73
OVERPAR73's Avatar
I tried, tried and tried again over the weekend with no luck! I think I'm just going to buy a new steering wheel and forget all the headache, I will let the dealership swap it out this spring.
Old 01-09-2014, 03:51 PM   #6
rgrmoreira13
so sorry for the wait. Again take a small screwdriver (flathead) and wiggle it to the opposite side. I.E if the slot is on the left then move it to the right if the slot is on the right then move it to the left. you should feel a small clip on each side.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
