01-13-2014, 05:59 PM | #1 |
Drives: 2014 RAM HEMI Join Date: Aug 2013
CAR WILL NOT MOVE!!!
Every time I wash it and pull it in my garage overnight I get ready to drive it the next day and it won't move
I put it in drive and today it wouldn't move. It just sits there, so I pressed the gas and it started bulking and gliding forward and then made this loud pop like a firearm. Once that happens the car drives great What is the problem? thank you |
01-13-2014, 06:10 PM | #2 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
brakes sticking?
2011 2SS/RS built 8/24/10
01-13-2014, 06:12 PM | #3 |
Drives: Car Join Date: Jan 2013
Dat ain't normul.
01-13-2014, 06:12 PM | #4 |
Let's go Rangers!
Normal after a wash. These rotors really rust up and when they do they grab. Scared the crap out if my the 1st couple of times it happened.
To avoid this drive it for a few minutes when you are done washing. Sent from my AGM, 2SS/RS |
01-13-2014, 06:13 PM | #5 |
Drives: 2010 1SS/RS Imperial Blue Metallic Join Date: Sep 2010
once you get done washing it drive it around for a mile or so before you park it in the garage if you can that will help remove the surface rust that gets on the rotors after washing.
01-13-2014, 06:13 PM | #6 |
Let's go Rangers!
See my above post.
01-13-2014, 06:14 PM | #7 |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
Do you set ebrake if so had old s-10 stick did same thing brake pads in the rotor hat rust to the rotor/hat drum and takes bit torque to bust them free I had to use big screwdriver and hammer in the winter sometimes to smack the rear hats to brake them free if was snowy or one side would break free and other wouldn't because would slide on snow locked wheel just sliding down road till I caught some pavement then blame freed up.
01-13-2014, 06:15 PM | #8 |
KaBoom1701
Mods:
01-13-2014, 06:15 PM | #9 |
Huh? Are being serious? The description in the op does not seem normal to me.
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
01-13-2014, 06:17 PM | #10 |
01-13-2014, 06:18 PM | #11 | |
Let's go Rangers!
Very serious. All that is happing is the brakes are rusting up and grabbing. The OP is making it sound a lot worse then it is, but it happens every time I wash the car and put it right into the garage without driving. Believe me it sounds a lot worse then it actually is. The pop is nothing more then the pad freeing itself from the rusted rotor. Sent from my AGM, 2SS/RS Last edited by nyrfan; 01-13-2014 at 07:16 PM. |
01-13-2014, 06:19 PM | #12 |
won't move
01-13-2014, 06:23 PM | #13 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
Look at the rotors after you wash it...they'll be all rusted....drive the car 5 minutes and apply the brakes to warm them up and they'll be shiny and not freeze...the sound your hearing is the rust actually breaking between the rotors and the pads.
01-13-2014, 06:25 PM | #14 |
Or use your leaf blower to knock the water out of the brakes/wheels after you wash it. It's the best way to dry your entire car also. Sticking brakes is definitely your problem (probably... maybe).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
