Old 04-08-2014, 02:24 PM   #1
ABMLS3
ABMLS3's Avatar
Drives: 2010 Aqua Blue Camaro 2SS/RS
IPS Oil return pump stopped working
I was sitting infront of my friends house just idling and my car started smoking like crazy so I shut it off right away and then turned the key a little to see if I can hear the pump because I can usually hear it... No oil pump sounds..
I've had so many problems with this kit first it took almost three months to get it, then when I got it a bunch of parts didn't fit right, so tune time had to custom make them which cost me a lot more money and more time for my car to just sit around waiting then another part that didn't fit had to be shipped by IPS and was supposed to be shipped over night but wasn't so that was another week of waiting and now this... I'm starting to wish I just got a whipple
Power Source Performance Turbo Kit
416 C.I ,TH400
Instagram: TomTraube
COTW ABMLS3 Build Thread
ABMLS3 is offline   Reply With Quote
Old 04-08-2014, 03:45 PM   #2
AGP Turbo
Drives: All things Turbocharged
If you need any parts from one of our kits, just call. 480-983-6083
We haven't had a failure of any kind.
AGP Turbo is offline   Reply With Quote
Old 04-08-2014, 04:20 PM   #3
ABMLS3
ABMLS3's Avatar
Thanks, IPS is sending me a new pump and wiring harness
416 C.I ,TH400
Old 04-09-2014, 01:14 AM   #4
Blk_SS
Drives: black on black 2SS/RS
Go with a turbowerx pump, I change my duel pump from hellion out after it failing on me and that thing work like a beast!
Blk_SS is offline   Reply With Quote
Old 04-09-2014, 07:40 AM   #5
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Yep, Turbowerx EXA pump here
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 04-09-2014, 01:42 PM   #6
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Agreed! I replaced the IPS supplied pump with a ExaPump
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 04-09-2014, 05:21 PM   #7
stevieturbo
Drives: it changes
The Exa is a beast of a pump.
When searching I never found a bad report about one. Lots of bad reports about pretty much every other pump out there though
stevieturbo is offline   Reply With Quote
Old 04-09-2014, 06:23 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Another vote for the Turbowerx EXA.... I blew up a turbo and scattered ball bearings and yes, they got into the scavenger pump...
Opened it up, at the racetrack... cleaned the balls bearings out and flushed it to ensure there were no metal chunks, put it back together and over a year later it's still spinning and grinning... I'll never run anything else...
Old 04-10-2014, 09:02 PM   #9
camarostar2010
Drives: 2011 SS
what pump is the ips set up using ? I also run the IPS set up. Now I am wondering. I don't need a pump failure.
camarostar2010 is offline   Reply With Quote
Old 04-11-2014, 01:34 PM   #10
stevieturbo
Drives: it changes
Post a picture of the pump.
Most kits ( all brands ) seem to use the cheaper pump, not the Exa. But couldnt say that for sure. Just any images Ive seen have all been the cheaper pump
Old 04-11-2014, 04:21 PM   #11
ABMLS3
ABMLS3's Avatar
This is the old pump, they told me they're sending me a pump and wiring harness and then I got it in the mail and all I got was a used pump..
This "new" pump only works when it wants too.. Randomly shuts off and is extremely loud, you can here it from 200 feet away probably. Louder then my engine/exhaust at idle and when I'm cruising at ~2000rpm I can still hear it
416 C.I ,TH400
Old 04-11-2014, 04:33 PM   #12
BullF-16
BullF-16's Avatar
That sucks. Get IPS to help you out with a Turbowerx exa. They're about $399 or so.
http://turbowerx.com/Scavenge_Pumps/.../Exa-Pump.html
Old 04-11-2014, 04:50 PM   #13
stevieturbo
Drives: it changes
I think the cheaper ones use straight gears, the Exa is helical, so are much quieter. Whether that's the cause of any noise or not I dont know.
The Exa on mine can be heard, but certainly not over the engine. Wouldnt really be any louder than most fuel pumps, but a much duller slower noise.
Plus the Exa can be mounted in any orientation
Old 04-11-2014, 04:54 PM   #14
ABMLS3
ABMLS3's Avatar
I think it's just that this pump is messed up, it's the same brand and model pump as the first one I had but this ones a lot louder. IPS is trying to tell me the wiring is what's cause the pump to not work and be so loud. At this point I just want them to I've me back the money paid for the pump and I'll get a different one, probably the turbo were that everyone is sayig they like
416 C.I ,TH400
