05-17-2014, 05:42 PM | #1 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Catch can - no oil being caught
First off I don't drive my car all that often and I have just under 2900 miles on my 2012 SS. I added an RX catch an about a year ago. I have changed out the drain hose with an open close valve. To date I have not gotten a drop out of the can. Normal? Everything is connected correctly.
I have a mike Norris can on my DD silverado and drain it each oil change and get at least a few ounces each time. Thoughts Pics Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
05-17-2014, 05:48 PM | #2 |
old school chevy rodder
lol you have a 2012 with 2900 miles on it...... I have a 2013 with 9k on it my daily driver...... you are not driving it enough.
05-17-2014, 07:37 PM | #3 |
Chu no guat a hasa is?
Drives: 14 Jeep G Cherokee Overland HEMI Join Date: Jun 2011
Thats one of tbe reasons i ditched RX. Went with elite. Wish i had gotten t
It from get go.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
05-17-2014, 08:26 PM | #4 |
For the first 1500 miles the re cc worked but now I am not catching anything either and the drain hole is in the off position. I now have 3400 miles on my 2011.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
05-18-2014, 02:28 PM | #5 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
How do you have it plumbed? Even a coke can with hoses running to it will catch something, as long as it's plumbed correctly.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-18-2014, 03:27 PM | #6 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Yea my apex can has about 35 miles on it, and 5 passes, not really any oil does have some metal flakes though probably just from putting in and taking out fittings trying to get the right configuration. Blew out my rear main seal because I had the clean side and dirty side t-fitted together going into the can to much pressure from boost and pop. Only running the dirty side with a check valve now and plan on a second can later.
05-18-2014, 06:42 PM | #7 | |
Drives: 2010 Camaro Join Date: Nov 2009
Something must be incorrect with your installation, or you need to remove the drain to see if it has somehow clogged. Critical for ALL v6 owners through 2013 to do the drill modification. |
05-18-2014, 07:11 PM | #8 |
Mine is a V8 and I had it apart to add the new drain
Ryan
Ryan
05-19-2014, 12:24 AM | #9 |
Search Ninja
where are the hoses running? Can you take a pic?
05-19-2014, 12:45 AM | #10 |
Drives: 11 Camaro V6 RS, 03 BMW Z4 Join Date: Oct 2013
The first time I tried to drain mine I also thought something was wrong because nothing came out as well, but I didn't wait long enough. The second time I tried (a few days later) I left it open for a few minutes and a lot of gunk finally slowly dripped out. I am using a RX catch can on a V6.
05-19-2014, 08:16 PM | #11 |
Pics
Ryan
Ryan
05-20-2014, 12:50 AM | #12 |
I am nearly 100 percent sure you have it on backwards. The middle nozzle of the can is the clean side which should go to the valley cover on the drivers side. The nozzle on the out side of the can is the dirty side which should behind the TB.
05-20-2014, 12:59 AM | #13 |
Search Ninja
Are you a LS3 or L99? They attach in different places. Your lines appear to run the way a L99 should be.
05-20-2014, 04:55 AM | #14 |
This is for 2010-2012 L99: Im pretty sure your hoses need to be switched on the can itself.
http://www.revxtreme.com/instruction...le%20Valve.pdf
