Old 06-09-2014, 09:13 PM   #1
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
2014 Chevrolet Z/28 Drive June 10 (UPDATED)
Some of you might remember last fall I was invited by GM to their Milford Proving Grounds to take a shotgun ride hot-lap in the new Z/28. I was hoping I behaved enough to get an invite back to actually be a pilot of this Rocket Ship that wears the sacred Z/28 badge. Well, I got the invite. Tomorrow is the day.
Stay tuned...
What a day what a day… I think I’m going to have Permagrin for days after piloting the new Z/28 around GingerMan Raceway.
First off, I want to thank Al, Mark, Monte and the rest of the Camaro Crew for inviting me down to GingerMan and allowing me the opportunity to drive the new Z/28. It was a great privilege and honor.
Now, let’s get to the good stuff…
Exterior
One of the best quotes about the design of the new Z/28 came from a friend of mine the first time I showed him a picture, “Man, that thing looks like it’s ready to punch you in the mouth without batting an eye”. I’m a really big fan of the Z’s exterior styling. I can honestly say there is nothing I would change. Nothing looks out of place. And of course we all know that every part of the exterior design is due to functionality. 410 more pounds of downforce, WOW! We had for color options to choose from with white being the only color missing from the lineup. It would be a hard choice if I had the 75 G’s to lay down on one of these Bad Boys. And yes, I drove every color option.
Interior
As most of you already know the Z has a matte finish with sued microfiber inserts that set the tone for a race-ready interior. The RECARO’s are nice, I’m a bigger guy and I must say they were very comfortable and fit me like a glove. I had plenty of support from the “aggressive bolsters” no matter how high the lateral G the Z pulled in the corners with me behind the wheel. I was able to ride shotgun for a few laps and the support in the passenger seat was outstanding. The flat bottom steering wheel is a nice feature giving me plenty of legroom. Now, my heel/toe shifting needs some work but I’m going to blame that on my size 13’s, they don’t listen to what my brain tells them… And let’s not forget about the short-throw shifter, it’s smooth and is at the perfect height for fast and hard shifts. The only issue I had was driver side seat height. The driver side seat was at its lowest position and my helmet still touched the headliner. It really was not that big of a deal once I was out throwing the Z into the turns. Later, when I was leaving the track and sat down in my SS I already missed the Z’s RECCARO’s, almost felt as if I was naked.
Drivetrain and Chassis
7.0 Liters of pure “Badassery” plane and simple. The LS7 is rated at 505 HP with 481 LB-FT Tourque. It’s mated to the TREMEC TR6060 aluminum 6-speed manual transmission with close-ratio gearing. The rear dif has a high-performance helical limited-slip differential and 3.91 gears.
As for the chassis the Z/28 has stiffer front and rear control arm bushings, increased spring rates and specifically Z/28 tuned anti-roll bars. The 305/30ZR19 Pirelli PZero Trofeo R’s on all four corners are a sight to see in person. The Z also has a lower center of gravity and customized control Dynamic Suspension Spool Valves, DSSV for short. The DSSV’s are factory-tuned and feature independent control of high- and low-speed compression and rebound, providing stiffness without affecting the Z’s ride comfort. Performance Traction Management has 5 Modes allowing for different levels of assistance depending on the driver’s skills. So, what does this all add up to? A tack capable BEAST that provides maximum grip during insane braking, hard acceleration and serious cornering.
The Drive
I was lucky enough to be one of the first on the track with Chriss Frezza as my copilot. The first couple laps we were escorted by Mark Stielow in a lead Z/28 showing us the ropes of GingerMan. Once everyone had two laps under their belt GM opened the track up and we were on our own, only limited by two lap intervals and our own driving skills.
I started off in Mode 3 – Sport as suggest by Al so I could get a feel for what the Z/28 had to offer. As I floored the accelerator going into turn one from the pits the sound from the LS7 was to die for. The exhaust note is perfect. The Z pulls hard, I can only imagine how big the smile on my face was. As I hit the first turn I was amazed at how much grip was available. I drove deep into turn two before using the massive Brembo’s to slow the Z down, came out of the turn and shot off like a rocket ship. Corner after corner I kept pushing more and more and the Z/28 did everything I wanted it to. The Z/28 is definitely a car that builds confidence in your driving skills. Later in the day I could feel Mode 3 limiting my driving skills so to say, so I was ready to move on to Mode 4 - Sport.
Now, Mode 4 - Sport Active Handling Off is defined as “for use by skilled drivers who are already familiar with a particular track. Dry conditions only. Requires more driver experience than Modes 2 and 3. Active Handling is off and available engine power is still limited to match Mode 3.” Yeah that sound like me right I’ve been in mode three all morning so time to step it up. Mode 4 was a blast letting you drive the Z harder into the corners and slide out with the front wheels pointed in the direction you wanted them to be in on exiting. Lap after lap this car just performs flawlessly.
The Z/28 is by far one of the best Track Ready production cars I have driven. I said it in my 2013 review and I'll say it again... The Z is definitely a "Track Ready Beast" that will embarrass some serious competition and then cruise the main strip home.
In closing, my advice to all new Z/28 owners - You Must find the nearest road course in your area and “track it” no excuses…
Our Z/28 Milford Proving Grounds Experience - 10/14/2013
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 06-10-2014, 05:58 AM   #2
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1
Sweet!!
swizlstik is offline   Reply With Quote
Old 06-10-2014, 09:28 AM   #3
Mr Twisty
Mr Twisty's Avatar
Nice!
What did you think?
-- Benjamin Franklin
Old 06-10-2014, 09:47 AM   #4
Tran
Administrator
Tran's Avatar
Some pics from today.
Old 06-10-2014, 09:42 PM   #5
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
A little Four off Landscaping....
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 06-11-2014, 10:32 AM   #6
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
http://youtu.be/x-kUYA-dVSw
T.
Ain't trying hard enough if you don't go field surfing every now and then!
BaylorCamaro is offline   Reply With Quote
Old 06-12-2014, 09:55 AM   #7
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Sounds like a great time. Makes sense they had you run the original course to keep speeds down.....
We do need to work on those lines there!
T.
I am surprised they don't offer more instruction at the media days....This driver was way off line as well.....I could help him drop 10+ seconds out of a single lap with just a little instruction
Old 06-12-2014, 12:45 PM   #8
tomster
RedLine
tomster's Avatar
Drives: 2022 ZL1 1LE
that car seemed to snap loose really fast!
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold)
2018 CTS-V "Black" (Sold)
2022 GMC 2500 "Blue"
2022 ZL1 1LE 6spd "Rapid Blue"
2023 ZL1 1LE Auto Rapid Blue (ordered)
tomster is offline   Reply With Quote
Old 06-12-2014, 01:49 PM   #9
LAWMAN
LAWMAN's Avatar
Drives: 2010 cam.2ss/rs.iom,07'escalade esv
awesome!!!
A9120159
1100:12/19/08
3800:06/19/09
6000:07/02/09
LAWMAN is offline   Reply With Quote
Old 06-12-2014, 02:05 PM   #10
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Looks like you had a lot of fun!!!
Sales @ CAI Inc is offline   Reply With Quote
Old 06-12-2014, 02:28 PM   #11
TBone
TBone's Avatar
Totally agree with these statements.
T.
Track fix.
Old 06-12-2014, 02:52 PM   #12
Dropspeed
Dropspeed's Avatar
That appeared to be driver error or inexperience at the track.
T.
To clarify, I am not knocking the driver as we all need to start somewhere. I am more surprised that journalist that are going to write about the car are let loose in cars with little experience or guidance.
The person that spun could go back and write about how the car is loose in the rear and is scary to drive. The readers would take his word for it having no idea his experience level on track
Now, I know nothing about that side of the automotive marketing world.....Maybe they just let them have fun and then they go home happy and write nice things. (not saying the Z/28 doesn't deserve the nice things said about it)
Old 06-12-2014, 08:00 PM   #13
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
I hate you!
Lucky *****
Old 06-12-2014, 08:10 PM   #14
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by Camaro_Corvette View Post
I hate you!
Lucky *****
both of them
