Old 07-17-2014, 06:12 PM   #1
Renstuka
Renstuka's Avatar
Drives: 2014 White LS Coupe, Manual trans
Normal Oil pressure in Bars?
Hi-
I have a V6 and just got the oil changed for the first time (1000 mi). What is the normal pressure in bars? Thanks
Renstuka is offline   Reply With Quote
Old 07-17-2014, 06:33 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
At idle, something around 4 bar give or take. One bar is 14.5PSI, and normal for the LFX engine is in the ~60PSI range.
Eric Baker is offline   Reply With Quote
Old 07-17-2014, 06:41 PM   #3
Au201
Drives: Black V6 auto 2LT RS
LLT:
1.2 bar at hot idle...
3 to 3.5 bar at 1500 rpm when hot...I don't know if the LFX is higher...
Sent from my bragging iPhone using an app that encourages it.
Au201 is offline   Reply With Quote
Old 07-17-2014, 06:50 PM   #4
Renstuka
Renstuka's Avatar
Thanks. at about 2000 rpm its reading 6 bar.
Old 07-17-2014, 06:52 PM   #5
Au201
That seems kind of high. Are you using 5W-30? And is the oil up to at least 200 degrees F (93*C) when you're seeing this?
Old 07-17-2014, 07:29 PM   #6
Renstuka
Renstuka's Avatar
Will check the temp and get back to you.
Old 07-17-2014, 07:57 PM   #7
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I hate idiot gauges...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 07-17-2014, 08:00 PM   #8
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Really? At idle? 60 PSI? That sounds incredibly high.
Originally Posted by Au201 View Post
LLT:
This sounds much more reasonable.
Just going by experience with PSI in other cars. I don't know for sure.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 07-17-2014, 10:44 PM   #9
Renstuka
Renstuka's Avatar
Just did a test run. Temp approx 120 500 rpm - 2.3 b
1000 rpm - 3.4 b
2000 rpm - 5.5 b
65 mph at 2000 6 b
New to these type of figures. Thanks for your input.
Old 07-18-2014, 07:18 PM   #10
Eric Baker
I thought the same thing. I thought it would be somewhere in the 30PSI range like my SS, but I looked into it and after some searching, it looks like the new V6 runs pretty high, because of the cam chain and VVT system.
Old 07-18-2014, 11:28 PM   #11
Au201
The V6 does run high, but not that high. At least mine doesn't on Pennzoil Platinum 5W-30. Tonight, oil at about 220 degrees, idle was 15 psi, 45 psi at 1500 rpm. "Off the charts" at 6500 rpm. Lol!
Pic from a while ago. Don't know why i took it but it works! Haha
