01-06-2015, 02:57 PM | #1 |
ZYJ
Drives: 2017 1SS Camaro/6 speed Join Date: Sep 2014
Car accident yesterday.... =( has anyone done a V6 to SS front fascia change?
At fault accident, sigh...
Driver side front fascia damaged, bent.:m ad0259::cr y: 2014 1LT/RS BLK Camaro, is this a good excuse to go for a ZL1 front fascia or 2014 SS front fascia? Does it going to work and fit perfectly with no problem without any modification? Has anyone tried this? Thanks... Last edited by hzisfrom1994; 01-06-2015 at 09:49 PM. |
01-06-2015, 03:04 PM | #2 |
Drives: 2014 Camaro 2LT/RS Ashen Grey Join Date: Apr 2014
Dam dude bummer... but I am curious too as to the process of converting my 2014 LT bumper to an SS or ZL1 bumper.
01-06-2015, 03:26 PM | #3 |
Drives: 2011 Black SS M6 Join Date: Oct 2010
If you got away without damaging your hood and fenders then you have about 600 dollars worth of repairs here. If you go with a ZL1 bumper, possibly 1,200 dollars.
Either way, accidents suck. I hope you get your car fixed quickly. |
01-06-2015, 03:27 PM | #4 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
There will need to be some modifications or replace the hood too so the hood cowl lines will match up.
The Bird is the word! |
01-06-2015, 03:37 PM | #5 |
ZYJ
The hood looks good, the fender is bent too... shit~
01-06-2015, 03:37 PM | #6 |
ZYJ
01-06-2015, 03:52 PM | #7 |
The 2014 v6 has the same hood as the 10-13 SS and V6 , the 2014 SS cowl and the 2012-2014 ZL1 cowl are wider and even those are different widths from each other. Others have tried, but a good body shop can modify either fascia to match whichever hood you want to use.
The Bird is the word! Last edited by Angrybird 12; 01-06-2015 at 04:07 PM. |
01-06-2015, 03:58 PM | #8 |
ZYJ
If my hood is fine from the accident (which it looks fine, I guess), I will keep the V6 hood, but I'd love to switch to a SS front fascia though.
01-06-2015, 04:07 PM | #9 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Did it scratch the headlight?
2011 2SS/RS built 8/24/10
01-06-2015, 04:22 PM | #10 |
If you're switching to a 14 SS front fascia, while it's unpainted just have the body shop sand down the cowl lines before they paint and install it.
If you swapped to a ZL1 fascia, would that work with a 2014? 14-15s have shorter headlights. Would that effect anything else? (outside of cowl lines.) That be my only question about the ZL1 route.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
01-06-2015, 04:30 PM | #11 | |
01-06-2015, 04:40 PM | #12 |
That's what I was thinking, but I didn't know for certain. It'd be an SS conversion for me then.
Taco's 2014 SS
01-06-2015, 09:45 PM | #13 |
ZYJ
I will go ahead for a SS front fascia then since it is easier and cheaper... has anyone done this? is there any specific mod in order to have the SS front fascia work on the V6?
THANks |
01-06-2015, 10:19 PM | #14 |
I think the 14/15 front ends are the same and on the V6 and V8. The change is the hood vent on the SS.
