Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 02-15-2015, 11:29 PM   #1
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
2010-2013 Chevrolet Camaro Multicolor Fog Light LEDs
I have a set of these from diode Dynamics. Nothing wrong with them, just want to change up. These will fit non RS cars when you buy them. RS drl's use a different housing. But I have them mounted in my RS. I had to buy non Rs fogs and mount them in that. They just pop in like the stock DRL for you RS guys. I lightly sealed the bulbs in with rtv clear,to prevent any water from entering.
I won't included the controller. You can pick up one for under 10 from ebay. Or ebay has a US seller that sells a bluetooth controller which you can control it from phone or ipod for about 40. Thats what I bought.
So you get 2 foglights($100) and 2 RGB bulbs($75.00)and in return you send me your RS fogs. Bulb doesn't matter. The only problem is my car is a DD. So I will need your RS fogs first. You can see by my Rating I'm trustworthy.
http://www.diodedynamics.com/store/2...fog-light-leds
If you want to buy it,make me an offer. No lowballers. Make me a fair offer for the fogs and ligts, I can include a controller for it as well.
2011 RJT is offline   Reply With Quote
Old 02-17-2015, 09:05 AM   #2
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
bump
Old 02-18-2015, 09:31 PM   #3
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
no one? Easier than cutting your fogs open for rings. This is all plug and play!
Old 02-21-2015, 02:17 PM   #4
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
Trade straight up for you RS DRL's. If you don't have the RS package, make an offer.
Old 02-22-2015, 03:49 AM   #5
azozrail1991
Drives: Camaro 2ss
50
azozrail1991 is offline   Reply With Quote
Old 02-22-2015, 05:24 AM   #6
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
Originally Posted by azozrail1991 View Post
50
Nope. just for the lights,maybe,but not for the fogs and lights.
Old 02-22-2015, 09:24 AM   #7
azozrail1991
Drives: Camaro 2ss
the lights and 15 for controller
Old 02-22-2015, 10:04 AM   #8
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
want to sell both. Have RS car, if I kept the fogs,couldn't hook up fogs to RS DRL connector. Easier for me to swap out your DRL's for my fogs and lights. I need RS drl housings because they have the PW13 connection. The non RS fogs have a different one. I forget the number. But the end that has the connector is not interchangeable
Old 02-22-2015, 06:29 PM   #9
azozrail1991
Drives: Camaro 2ss
my car ha RS package, they wont fit?
Old 02-23-2015, 01:44 AM   #10
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
please read. You'd have to take your housings out,then replace with non RS fog lights. They are the same thing as the RS lights EXCEPT for the bulb and how the cars wiring hook to the bulb. You just have to pop off the trim around the drl's. if you can get the car on ramps,slide under the front end and look up at the drls. There are 3 plastic things you have to squeeze in and push out towards front one at a time. DRL will pop out. You just disconnect the harness and one side is done. If I sent you mine you would just pop the light in,run the wires to where ever you mounted a controller. the power to the controller and you're done. You don't use the stock hook up.
Old 02-23-2015, 09:12 PM   #11
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
Pop out your DRL's and send them to me. http://www.camaro5.com/forums/showthread.php?t=74684
I will send you mine with the led's already installed. Just hook up a power and ground get a controller http://www.ebay.com/itm/44-KEY-24-KE...item233c987362 and your set.
Old 02-24-2015, 07:15 AM   #12
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
To simplify this I need a set of housings that accept the P13W bulbs NOT the 5202 bulbs. In return you will get housings that accept 5202 bulbs,the RGB leds,etc. The housings are interchangeable to any model. Its the factory harness that is different. (RS cars have P13W plugs and non RS have 5202 plugs)
Old 02-25-2015, 10:58 PM   #13
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
bump
Old 02-27-2015, 01:54 AM   #14
2011 RJT
2011 RJT's Avatar
Drives: 2011 RJT/RS
pic showing how the bulbs connect to the light housing. Notice how different...
