03-08-2015, 03:41 AM | #1 |
BUMBL Z
Very weak RS HID light output
Ever since I got my '10 SS last year, i've always thought that the OEM RS HIDs were rather weak and not strong. I've actually driven halogen-lit vehicles that i'll say easily outshine the lights on my camaro. I've read a lot of mixed reviews on previous threads, and was just wondering if maybe chevy switched the manufacturers or something for their HIDs earlier on?
I tried a new set of bulbs from Diode Dynamics, and while they were a hair brighter, they're still not at all where I think it should be. I keep almost nailing potholes because I can barely see the road! Does anyone think that something could be up? Maybe my ballasts are starting to die since they're about 6 years old (car was built in 09) as of now?
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
03-08-2015, 04:23 AM | #2 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
Something's wrong if you think the 4300k hids are not bright. The stock lights are highest lumens output bulb you can buy. diode dynamics aren't brughter then oem or the same quality.
03-08-2015, 12:56 PM | #3 | |
BUMBL Z
This isn't one of those "oh there must be something wrong with you if you think the stock HIDs aren't bright" (i've seen this pop up on a LOT of previous threads) things because i've parked next to my mom's lincoln mkx and my dad's F-150, both of which have factory-equipped HID's and theirs blew mine straight out of the water with both sets of bulbs. Even my sister's Jeep GC, which has HALOGEN-projectors, was leaps and bounds brighter than mine on both sets. There has to be something wrong here. I won't mind spending some coin on a good set of bulbs, anything to allow me to see the road again at night.
03-08-2015, 03:41 PM | #4 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
If you do have a "flashlight" brighter then the headlight, you have problems, and it may be the car, but the OEM headlights are HID and with 4300K bulbs you want get a lot more light out of them.
03-08-2015, 03:44 PM | #5 | |
Vrrrm.
Did you notice the color of the bulb its blueish white and you lose a lot of light when you use a higher "K" rated bulb. I personally wont run higher then Run 5000k or 5100k or 5200k. Its a pure white sure I lose a little bit of light throw but not a lot and it matches much better to the halos. I also buy a good brand Such as PIAA Alstare and not diode dynamics generic bulbs never know who they get theres from.
03-08-2015, 04:15 PM | #6 |
Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
I have diode dynamics 8k bulbs and they are plenty bright...maybe check the aim of the projector? Or maybe ballast is bad and not the bulbs??
03-08-2015, 09:01 PM | #7 |
BUMBL Z
I understand how kelvin temps work, I've been using hids for quite some time, but the output I'm getting is atrocious. Even my girlfriend noticed that they're way too dim. I'll get new osram bulbs, but I really don't think they're the problem here. Projectors are also aimed fine. Ofer, you mentioned something wrong with the car? Do you have any specifics in mind?
03-09-2015, 11:26 AM | #8 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
You may need new bulbs.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
03-09-2015, 11:31 AM | #9 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
i would suggest you check the ground wire.if you have a bad connection it would cause the problem.i always like to check the simple things first.
03-09-2015, 02:23 PM | #10 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
Hey dude that must be frustrating
I don't think it would be your ballasts though My car is 6 years old as well and just burnt out the hids recently Apart from that I can't see how the ballast would go bad Ground connection sounds like a start I'm no mechanic But if it were my car, I would buy the stock hids plus change fuses for the sake of it Double check all my wires Make sure headlights aren't oxidized You think maybe the grill is blocking quite a bit of the light?
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
03-09-2015, 02:38 PM | #11 |
BUMBL Z
I already placed the order for new ballasts, so we'll have to see. If no difference, then i'll send them back. I'm going to try with both the diode bulbs and the stock bulbs i got left.
What ground wire are we talking about? the ground wire going to the ballast? I'm still really not entirely sold that it would be the bulbs after replacing them. I mean, these ballasts are only rated for 2000 hours. that's just under 84 complete-day's worth of operation, over 6 years? Seems quite possible that i'm far over that. If it is the ballasts, then good for me, i called it. If not, then i'll return them and get replacement osrams or philips
03-09-2015, 03:37 PM | #12 | |
We think the cold in the US this winter may be lowering the volts to the headlights, So try and find out what volts you have to the headlights. |
03-09-2015, 08:07 PM | #13 |
BUMBL Z
Also forgot to mention, I have a brand new interstate megatron plus in there. I'll take a meter to it this weekend when I have everything off, but they've been dim even back to when weather was brighter. I'll see what's going on, but ultimately I'm going to also swap the ballasts and see if that makes a difference, because I have a strong feeling that's what's going on
03-10-2015, 12:56 AM | #14 |
Drives: 2015 2ss 1le Join Date: Mar 2015
how do your highs perform. I just got my car a few days ago and the lights don't seem to project that far. when I put on the high beams it lights up the road for miles. I have a feeling it might have to do with the height of the car and the fact they have to be aimed low as to night blind other drivers. I have an 05 jeep grand Cherokee that with halogens and it seem to light up more of the road directly in front of me. my previous car was a Buick GS that had the same kind of hids. I would sometimes find myself turning them off and on to check to see if they where on.
