Old 05-16-2015, 03:58 PM   #1
tonyfred
tonyfred's Avatar
Drives: 2013 ZL1-Victory Red-Auto
APR Carbon Fiber Front Splitter Installed
Not a bad install. I didnt remove the fascia. Used large washers to support the rods behind the grill. Still not sure if I will leave them on or not. It was very secure without them. I drilled the holes in the splitter for them but a couple of rubber grommets wouldnt look bad to fill the holes if I decide to take them off.
tonyfred is offline   Reply With Quote
Old 05-16-2015, 04:47 PM   #2
BigBlock427
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1
Hey we are twins! I love mine too... I am waiting on my tow hook and the rest of my aero sports kit to come in to take of the front bumper and do the struts. we even have the same scrape on the stock splitter.
BigBlock427 is offline   Reply With Quote
Old 05-16-2015, 06:18 PM   #3
Mike-ZL1
Mike-ZL1's Avatar
Drives: 2014 ZL1 Camaro
ARP splitter
I have this splitter to. love it makes the front end look much more aggressive I installed the struts also there is a lot of force on it at speed so I decided to be safe than sorry congrats looks great
Mike-ZL1 is offline   Reply With Quote
Old 05-16-2015, 07:53 PM   #4
Aero_Sport_Concepts
aerosportconcepts@gmail
Aero_Sport_Concepts's Avatar
Drives: '15 1SS-RS/1LE (RRM)
Your Kit was shipped out yesterday bud. Post up pics when you get it installed
Thank you
Kurt Robinson
Aero Sport Concepts
Aero_Sport_Concepts is offline   Reply With Quote
Old 05-18-2015, 10:50 AM   #5
rjs2010SS
rjs2010SS's Avatar
Drives: 2013 AGM ZL1 BELLA*
I installed this on mine as well, I didn't however install the struts, but I haven't had any issues with it at high speeds yet lol. I have had it on now for about a year.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella*
2010 MGM Toyota Tacoma
2010 CGM SS (Traded)
1996 Black SS (Sold)
rjs2010SS is offline   Reply With Quote
Old 05-18-2015, 05:18 PM   #6
csmith4153
csmith4153's Avatar
Drives: 2011 1SS
How do these mount? Factory screws or do you need to drill holes in the underside?
csmith4153 is offline   Reply With Quote
Old 05-18-2015, 08:25 PM   #7
mat300z
Emerald Coast Camaro's
mat300z's Avatar
Drives: 2014 ZL1
uses factory screws and there are a lot of them!
mat300z is offline   Reply With Quote
Old 05-18-2015, 08:34 PM   #8
mat300z
mat300z's Avatar
Drives: 2014 ZL1
you still have to drill the holes in the splitter...a little pain but worth it
Old 05-18-2015, 09:56 PM   #9
tonyfred
tonyfred's Avatar
Factory screws for me plus I added several more to be sure. The generic instructions called for bolts (provided) but I felt it was very secure with the screws and washers I used. You will have to get creative to mount the rods. I used large washers with very small holes. Connected the end of the rod to the washer and worked it through the grill and it fit securely behind the grill slats. Then drilled the holes in the splitter and connected the rods there. Once you tighten it all up it is very secure. I painted the washers flat black and they are practically invisible. I saw various methods...mounting angle aluminum behind the grill, etc. But this seemed like the least painful approach without removing the fascia.
Old 05-18-2015, 10:00 PM   #10
tonyfred
tonyfred's Avatar
I raised the front end using Race Ramps. It was very easy to get to everything then. I used a couple of jack stands to hold the splitter in place. It is well made and fit perfectly. Drilled holes in each side and middle. Then it was a cinch to secure the other screws. I thought about using some kind of epoxy but decided not to. It tightened up very nicely.
Old 05-18-2015, 10:03 PM   #11
tonyfred
tonyfred's Avatar
Originally Posted by CreativeDawn View Post
Is there an APR Splitter for the 2010 V6 Camaro?
Havent ran across one but that doesnt mean they arent out there.
Old 05-19-2015, 05:39 AM   #12
mat300z
mat300z's Avatar
Drives: 2014 ZL1
Originally Posted by Nathan Moreno View Post
Looks good Tony. Is there a way to get rid of the APR logo?
Yeah I am pretty sure its just a decal...I will go out and check here in a minute
Old 05-19-2015, 05:43 AM   #13
mat300z
mat300z's Avatar
Drives: 2014 ZL1
As for getting creative to mount the rods I put mine in place so I can change the look if I want. The rods can be swung outward and connect to the side of the upper factory splitter or I can leave them as they are now. Just an Idea for those of you who haven't installed the rods yet.
Old 05-19-2015, 05:52 AM   #14
Mike-ZL1
Mike-ZL1's Avatar
ARP splitter
Yes just a decal comes right off I used factory hardware also
