07-07-2015, 06:20 AM | #1 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
I need a bulb. And my Owner's manual says...
...on page 10-46 "Vehicle Care", in the 'replacement bulb' chart, that I may have as an exterior lamp:
Daytime Running Lamp (Uplevel vehicles) Bulb number PSX26W ...or I may have... Fog Lamp (except for ZL 1) Bulb number PSX26W Really. I might need a PSX26W, or maybe I might need a PSX26W. Interesting. The real fun comes when I read the directions for replacing the bulbs on page 10-45. It's like Cliff's Notes met a Hayne's manual and spawned a non-talkative child. In a nutshell: 1) locate bulb under fascia 2) Disconnect electrical connector and remove bulb 3) install new bulb 4) reconnect electrical connector. Fascinatingly technical. Why didn't they just print: 1) Reverse procedure for installation (see step 2) 2) Reverse procedure for removal (see step 1)
07-07-2015, 06:39 AM | #2 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Step 1 should be the 'warning'.
1. This is going to be a pain in the a$$, so be ready to cuss. |
07-07-2015, 07:57 AM | #3 |
old school chevy rodder
unstall a LED running lamp instead a 13W will be so much brighter....I got mine form automotivelightstore.com and do both...
07-07-2015, 08:51 AM | #4 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
Spend the extra and purchase an authentic CREE LED
07-07-2015, 11:31 AM | #5 |
Drives: 2012 Crystal Red Tintcoat RS Join Date: Apr 2013
Go Cree LED and get the wiring harness so they stay on with your headlights, you'll really like it. LED's burn cooler and match the HID's better.
07-07-2015, 11:45 AM | #6 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
y'all forgot to put in the step to tell you that to access the DRL/FOG's you need to remove some of the inner fender well to get to the back of the fascia and the back of the housing! lol
07-07-2015, 02:42 PM | #7 | |
Buick 455 Fan
It literally says, verbatim: 1. Locate the bulb assembly under the front fascia. 2. Disconnect the electrical connector from the bulb assembly and pull out the bulb assembly. 3. Push in the new bulb assembly to lock it into place. 4. Reconnect the electrical connector to the bulb assembly. Word for word those are the instructions. May as well say "to replace bulb remove bad bulb, install new bulb". Works for anything really. I should be a technical writer at this point. Watch this, I can do as good a job: Camshaft replacement/installation, pushrod V8 engine: 1) Open hood 2) Use required tools to remove camshaft 3) Install replacement camshaft by reversing procedure in step 2 4) Close hood Totally Car Craft stuff, right? I know! But why stop there? I can be a brain surgeon at this rate! I already know how: 1) render "patient" unconscious using what have you, mallet preferred. 2) saw open head at top 3) fix up the brains with medical knowledge and required tools [note: step 3 is critical] 4) put chunks of skull back on head, tape in place 5) leave bill where "patient" can find it when (if) "patient" awakes 6) flee, in case "patient" fails to awaken
07-07-2015, 02:59 PM | #8 |
Drives: 2015 Camaro SS Join Date: Jan 2015
Camshaft DIY bookmarked for later use.
07-07-2015, 03:28 PM | #9 |
Drives: 2013 Camaro 2SS/RS Join Date: Apr 2014
The removal and installation of drl lights is easy to do.
07-07-2015, 05:40 PM | #10 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Not needed. there is a small access hole under the front fascia to reach in and change them.
07-07-2015, 05:49 PM | #11 | |
Drives: 2012 2SS Join Date: Jan 2015
My boss once said the only thing more dangerous than a technician that doesn't do what you say, is a tech that does EXACTLY and ONLY what you say. I've met techs who would not think twice about putting the old bulb back in since the "book said so". |
07-07-2015, 05:58 PM | #12 | |
Buick 455 Fan
What I posted was not a serious attempt at a real procedure. You have been fooled by a devilishly underhanded post.
07-07-2015, 06:06 PM | #13 |
KNGTFALL
I can see it now.
DIYs Open glove box read the manual. The end |
07-07-2015, 06:55 PM | #14 | |
