Old 08-07-2015, 03:24 PM   #1
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
Rupes Results...
I finally upgraded from a Porter Cable to a Rupes after trying the Rupes at the Syracuse Nationals.
It operates so much more smoothly, and I was hoping that it would not hurt my wrists like the PC.
Well, after 4 hours of polish-polish-wax, my wrists were happy and the result was fantastic.
The smooth operation really seems to make it a more effective tool.
I used Wolfgang Total Swirl Remover & Finishing Glaze on the paint, and Adam's Brilliant Glaze on the paint protection film.
Pinnacle Liquid Souverän wax was used on all.
Now the paint positively glows in the sun.
ZL1 Camaro - Worlds Largest Sports Car
Road King - Not Garage Queen
2014CamaroZL1 is offline   Reply With Quote
Old 08-07-2015, 04:50 PM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Looks great! My BF 21 is in transit! Did you use the washer mod?
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 08-07-2015, 05:12 PM   #3
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Looks great!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 08-08-2015, 04:42 PM   #4
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
I've always hand polished. I think I'm going to skip the PC and go straight to the Rupes 21 or Flex 3401.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 08-08-2015, 06:33 PM   #5
Joe M 2012 2SS
Drives: 2012 2SS
If you've never used a polishing machine, the Flex could be a bit much to start out with. It's direct drive and will have a tendency to "walk" on you if the pad is not kept completely flat to the surface.
The 21mm throw of the Rupes is great for fast correction, but is limited on pad size and really isn't made for the smaller areas of the car.
The Griots Garage 6" has more power then the PC, also carries a lifetime warranty, and you can use a wide variety of backing plate sizes with it.
If your just moving to machine polishing I'd recommend the Griots 6". While it won't correct as fast as the Flex or Rupes, it's very user friendly.
Old 08-10-2015, 03:12 PM   #6
2014CamaroZL1
You are going to love the BF.
What is the washer mod ?
Old 08-10-2015, 03:14 PM   #7
2014CamaroZL1
I cannot speak to the Flex...
But I will vouch for the Rupes BF 15 as being very user friendly.
Compared to the PC, it is much smoother and nicer to use.
The 15 may be the better size unless you are doing pickup or vans or boats, or need to maximize your productivity.
Old 08-10-2015, 05:29 PM   #8
Joe M 2012 2SS
Drives: 2012 2SS
Adding a washer to make the machine free spinning instead of having the anti-spin shroud normal set up.
Old 08-10-2015, 05:42 PM   #9
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
you're ****ing crazy, I don't even know how to hand polish anymore. Start with the PC, it's a great learning device. Once you gain more knowledge then move up to a faster better polisher otherwise you have the likelihood of damaging the paint.
Knockoutpie is offline   Reply With Quote
Old 08-10-2015, 08:55 PM   #10
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
I 100% disagree.
The rupes is easier to use than the PC. If you can afford it, get the Rupes and skip the PC altogether.
If you're talking Flex or rotary which are harder to use than the PC, then yeah get the PC first. But the rupes is just so easy to use.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 08-12-2015, 12:19 PM   #11
Dubscamaro
Living Life in MPH.
Dubscamaro's Avatar
Drives: 15 Summit White 2SS 1LE
Your arms must be huge...or sore all the time. LOL I love my Flex polisher. It's a self-correcting polisher. I'm pretty sure the BF is also.
Dubscamaro is offline   Reply With Quote
Old 08-12-2015, 12:42 PM   #12
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I use the FLEX for heavy correction, Normal polishing or waxing and sealants I use the PC.
Flex is pretty heavy to use for polish and lighter stuff.
-bobby
My Glow..
http://[/IMG]
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 08-13-2015, 12:07 PM   #13
2014CamaroZL1
Originally Posted by bobby35ny View Post
My Glow..
Very nice !
Old 08-16-2015, 01:25 AM   #14
mrbe
Drives: 2012 45th anniversary comero Borla
How much hp u got out the box
mrbe is offline   Reply With Quote
