Old 08-12-2015, 09:16 PM   #1
Sickness91Z28
Reaper Crew
Sickness91Z28's Avatar
Drives: Blown 2010 Camaro SS
Pedders problem?
Sickness91Z28 is offline   Reply With Quote
Old 08-13-2015, 05:04 PM   #2
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
have you called lpw Im sure they will help you
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 08-14-2015, 10:59 PM   #3
Sickness91Z28
Reaper Crew
Question
Does anyone know much about actual spring rates?
I have adjusted and adjusted these coil overs....and they are bottomed out. It will not go any lower at all and it's at about stock ride height.
The coilovers are the Lingenfelter/Pedders Supercar DRAG Coilovers.
The fronts have this stamped on them: 62 250 04.5
The rears have this stamped on them: 110 62 170 012
I have not installed the rear yet because I'm having some many problem with the front not lowering. I can increase he ride height with no problem....but it will not go any lower with the lower body all the way in.
Does anyone know since these are the "DRAG" coilovers....if they will not lower the car?
I thought maybe if I were to get another set of springs (more of a street spring) they would lower the car. ANY info would be great
2010 Camaro SS
SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP
Pedders XA Coilovers
Old 08-14-2015, 11:55 PM   #4
Sickness91Z28
Reaper Crew
Here are a few pictures. It's completely bottomed out, should be as low as shit
2010 Camaro SS
Old 08-14-2015, 11:56 PM   #5
Sickness91Z28
Reaper Crew
Looks stock
2010 Camaro SS
Old 08-15-2015, 02:45 AM   #6
sting808
Drives: 2010 SS RS
Not sure what the specs on the actually coil-over, but the coils are read as:
62 250 04.5
62mm DIA (close to std 2.5" coils used by other manufacturers designs)
250mm length (about 9.84", std Pedders XAs use 180mm or 7")
04.5kg or 252lbs spring rate (std Pedders XAs use 8kg or 448lbs)
Forgive me but this may be a stupid question, but did you roll the vehicle to reset the suspension after dropping it to the ground?
I've tried 150lbs(10"), 250lbs(8"), 325lbs(8"), and 560lbs(?") springs on my front. Everything under 8kg(7") dropped the vehicle height where I needed to raise it to get it back to the same 1" drop with the 8kg spring. My car weighs 4300 lbs w/driver and has a KB 2.8. My Pedders XA may be different design from yours. I'm sure Lingenfelter would provide info info for you.
Try giving Lingenfelter a call.
sting808 is offline   Reply With Quote
Old 08-15-2015, 08:29 AM   #7
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Did you re-time the bushings??? It will make a big difference!
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 08-15-2015, 08:36 AM   #8
rockrau
rockrau's Avatar
Have you tried to get ahold of Justice Pete @ JPSS? He is a sponsor, used to be Pedders USA.
Old 08-15-2015, 08:40 AM   #9
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Can we see the actual coilover as it sits on the car?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 08-15-2015, 08:49 AM   #10
rockrau
rockrau's Avatar
http://www.camaro5.com/forums/showpo...&postcount=485
Copy this URL and check this out.
Old 08-15-2015, 11:22 AM   #11
Sickness91Z28
Reaper Crew
Here it is, installed. The only way I could get it to go all the way down (lowest ride height even though it still sits like a truck) I had to compress the spring with the nuts. I had to tighten the spring down a lot in order for much adjustment as far as ride height. Again, it's like the spring is just way to long or stiff
2010 Camaro SS
Old 08-15-2015, 04:26 PM   #12
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Ride height should be adjusted by the upper two rings. Bring the center one down closer to the bottom one and the upper one snug up again the middle one. I think I have 35mm between the lower and middle one on mine. I don't have my car here or I would take a pic and measure for you. I am lowered as much as you can safely go with these coilovers.
mp51998 is offline   Reply With Quote
Old 08-15-2015, 04:51 PM   #13
Sickness91Z28
Reaper Crew
If I do that, I run out of adjustment. Like the spring is waaaay to long.
According to the measurements giving above, the drag coil over springs are about 3" taller than the standard pedder coilovers. Wonder if that is the problem?
Again, these are the Lingenfelter/Pedder Supercar Drag Coilovers, not the standard pedder coil overs.
2010 Camaro SS
Old 08-15-2015, 04:59 PM   #14
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Just trying to help. Not a pro. From what I have seen u have to raise the lower ring and turn down the top ring to lower. Have u tried that?
