Old 12-08-2015, 08:50 AM   #1
flyby
Drives: 2010 Silver SS
New Personal Bst
Went to the track with some good results. Weather not cooperating (low 50's into a headwind of about 15-20 mph). Track not very good either, difficult time getting traction (track closed a few days later for the year to resurface).
Hopefully with better track and no headwind should be able to get into 9.5 to 9.4 area with no car changes.
flyby is offline   Reply With Quote
Old 12-08-2015, 10:47 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Thats fast. Details about the car?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 12-08-2015, 12:28 PM   #3
flyby
I have been working on this car since I got it in August of 2009. Many of the modifications on the car are one of a kind or first to be on a Gen 5. The car has gone from an M-6 to the current 4L80E. From stock suspension to its current 15" BMR (mostly) suspension. One of the first Driveshaft Shop 9" rears. Mast lack label then flow modified heads. Custom grind from comp cams (no details to be given out). Procharger F-1, etc.
Old 12-08-2015, 04:00 PM   #4
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
wow that killing it.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 12-08-2015, 08:15 PM   #5
bct10985
What motor?
Old 12-09-2015, 06:57 AM   #6
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 2018 Colorado
That's cooking, I've seen that car before nice work. You should've been there on the 27th (Black Friday). 10+ degrees warmer, track pretty good.
molsonbrador is offline   Reply With Quote
Old 12-09-2015, 10:16 AM   #7
flyby
The motor is an LS 3.
Old 12-09-2015, 01:08 PM   #8
bct10985
Stock bottom end is what i meant to ask
Old 12-09-2015, 06:02 PM   #9
flyby
Yes
Old 12-09-2015, 06:12 PM   #10
bct10985
Damn 144 is flying on a stock bottom end. Have you ever dynoed it?
Old 12-10-2015, 07:09 AM   #11
flyby
Just for tuning purposes
