01-24-2016, 09:02 PM | #1 |
How often do you need to add oil to your 1LE
I was wondering of this because today I had to add 2 quarts of oil to my car. (5W30) and I DD the car. I don't take it to the track just my daily commute and the usual pulls on the highway when it is clear. So I keep getting notices that the oil is super low and I check the dipstick and sure enough it is. So if it is not the sensor what else can burn oil so much ?
If it is any relevance the average temp (based off the sensor on the car) of the oil is around 230 to 238 (Once I reach 240 I try to slow down cause I know it is getting too hot)
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
01-24-2016, 09:15 PM | #2 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Something odd happening there. I might go thru a quarter quart to half at most, with mixed heavy/little track/easy weekend driving per season (six-seven months). No leaks? Find a good dealer nearby and get it checked out
"Make yourself sheep and the wolves will eat you"
01-24-2016, 09:28 PM | #3 |
no leaks when I have checked. No burning smell. No smoke coming from the exhaust so I don't know what is going on. That was my next plan of attack actually to take it to the dealer and see what is going on.
Specs
01-24-2016, 09:29 PM | #4 |
Can you give some more detail? How long have you owned it? Did you change the oil yourself? Someone else do it for you? Have you checked it periodically? I ordered a 12 RS before I traded it for my 13 1le. I took delivery of my RS and the steering felt weird ( 12 RS had hydraulic steering, unlike our electric ones on the 13 and up). Dealer said it felt fine to them. I took the engine cover off and the factory worker in charge of fluids must have had a bad day. Most of the power steering fluid was poured around the filler, not in the reservoir. Took it back, dealer cleaned it all up, refilled it, all was fine. My point is if you didn't fill it yourself, don't worry yet. Maybe the jackass who worked on it set the pump to 6 quarts not 8 and over a few weeks/months time, it went low enough to trigger a light.
01-24-2016, 09:41 PM | #5 |
Drives: 2018 red hot 1le Join Date: Apr 2015
Mine doesn't use a drop and I have 10k miles on it.
01-24-2016, 10:15 PM | #6 | |
I have owned the car since August 14, 2015. I have a V6 before (1LS) I upgraded to a 1LE. I did my first oil change and I added 8 quarts of oil. ( I had to look up a youtube video on where to drain the oil etc.) and I hadn't had a problem until today. I had to add 2 quarts of oil so that there can be adequate amount of oil. (Up to the 3rd hole on the dipstick I believe ?)
Specs
01-24-2016, 10:33 PM | #7 |
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
11k miles on mine and have never needed to add oil between oil changes.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
01-24-2016, 10:42 PM | #8 |
Drives: 2013 Camaro 2SS/1LE Join Date: Aug 2012
Mine was leaking because the seal on the oil filter was bad. took it to the dealer and they did an oil change and replaced my oil filter.
01-24-2016, 10:46 PM | #9 | |
01-24-2016, 11:50 PM | #10 |
Tri-County Camaro SWFL
OP if your car is still in break in ( less than 1500 miles)I wouldn't worry. 2 quarts is a bit much either way. But if its break in I wouldn't worry that much.
01-25-2016, 10:12 AM | #11 |
Drives: 1LE Join Date: Feb 2013
GM has put on a technical bulletin saying 1 qt every 2000 miles is "normal" under "normal driving" conditions for the LS motors.
It further states that more oil loss is considered normal if the car is in break-in (defined as under 4000 miles) or is driven hard. It goes on to say that the hard driving (for the sake of oil usage consideration) is when you regularly go over 3000 RPM before shifting. Point here, there will be many folks who scream that their car doesn't use a drop. That's great and all, but oil consumption will vary, and GM will not take action unless they do an oil usage analysis and come up with something more extreme than I described here. If you do a search on this forum, you will find many opinions on what folks THINK is normal to them. There are also threads about "excessive" oil in catch cans -- when the actual amounts caught, while alarming at first sight, are actually far less than the allowable usage amounts described here. So, if you lost that 2 quarts during break-in, under hard driving, and over a period of 4000+ miles -- or some combination thereof -- than you really still fall within "normal." For those that do use some oil, you can also expect oil usage to drop after break-in. |
01-25-2016, 10:24 AM | #12 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Mine has just over 5k on it and I did my first oil change at around 1500 miles, I do drive it hard sometimes just because race car, lol, but did notice before I put it up for winter a few months ago I was down about a quart so I added some.
UPSTATE C5 MEMBER
01-25-2016, 11:49 AM | #13 | |
Drives: ‘13 1LE Join Date: Jul 2013
01-25-2016, 11:56 AM | #14 |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
+1... a little over 11K on mine.
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
