05-24-2016, 05:32 PM | #1 |
Drives: A Gift From My Wife Join Date: Apr 2009
Simple Green and a Garden Hose
For the engine bay?
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping. 08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery). 08/16/2011 - (5000) Vehicle has been delivered to dealer. 08/19/2011 - In my possession. |
05-24-2016, 05:34 PM | #2 |
Drives: camaro Join Date: Aug 2015
and a brush. don't use a pressure washer unless you have an extremely dirty engine bay. mcguires foaming tire shine on everything after the green and hose will make it look new again.
1969 pro street
heads/cam/blown/meth 408 LS |
05-24-2016, 06:50 PM | #3 |
Drives: 2012 1LT Join Date: Nov 2015
On a 5th Gen Camaro, why do you believe you can't you use a pressure washer? All the electrical connectors are water tight.
05-24-2016, 07:05 PM | #4 |
Too much pressure, don't want to blow any hoses off or inject water where is doesn't belong.
Its not filthy enough to require a brush. Thanks for the advice..
05-24-2016, 07:26 PM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Great for the wheels too.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
06-03-2016, 04:19 PM | #6 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
I power wash my engine bay all the time. Never had a single problem. I work in a very dirty, dusty environment, and even when parked the dirt/dust finds its way under the hood. I clean my Cold Air Inductions filter 3-5 times a year.
Meh
06-05-2016, 07:24 AM | #7 |
Yup, what My 5th just stated. I do the same on just about any vehicle using the OBD II. Damn near everything is water tight under the hood. You won't blow off hoses or damage electronics. Makes the job so much easier!
06-08-2016, 04:12 AM | #8 |
Drives: 2010 Join Date: Mar 2015
Simple Green is a good cleaner but it can speed up the corrosion process on bare aluminums. I like using Purple Power. This product can be diluted depending on how dirty your engine bay.
06-08-2016, 05:16 AM | #9 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Cover alternator?
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
06-08-2016, 05:24 AM | #10 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Dont ever ever use that on paint, glass, etc. Will etch badly!
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
06-08-2016, 05:49 AM | #11 |
If it makes you feel better then go ahead and cover it. I don't. However, I don't deliberately spray from my high pressure wand directly at the alternator either. The garden hose shouldn't have enough pressure to cause any harm. I do scrub it with an All Purpose Cleaner and brush if dirty.
Modern electronics are water tight.
