07-26-2016, 03:19 PM | #1 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Square Wheel/Tire Set-up on ZL1
Who out there is running this set up on their car? Advantages/disadvantages?
Are you using 11 in wheels all the way around or 10.5? Same size tires all the way around? Do tell.
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
07-26-2016, 03:59 PM | #2 |
Drives: Camaro Justice Join Date: Jun 2007
The reason they run a square setup on the Z/28 is balance. The car handles better. So will a ZL1. Generally I have 11 wide front and 11.5 rears made for my clients.
07-27-2016, 07:13 AM | #3 |
I thought maybe handling would be better with wheels and tires all the same size. Also they could be rotated. So how is 11 in wide fronts and 11.5 in rears ( on 20 in wheels) square? I thought both tires and rims would need to be exact same size all the way around, like i ran on my 67 Camaro?
OHIO |
07-27-2016, 11:01 AM | #4 | |
Drives: 2013 2SS (sold) Join Date: Jan 2016
This is the setup the 1LE/Z28 have. Wheel widths are different front/rear but tire sizes are the same all 4 corners. He is referring to a square setup of "tires", not "wheels+tires". So obviously you couldn't rotate them
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
07-27-2016, 05:10 PM | #5 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Been running square since 3500 miles or 2 years ago on replicas 285/35/20, love it. The original rims and Goodyears remained stored.
07-27-2016, 05:16 PM | #6 | |
07-27-2016, 07:40 PM | #7 |
I run square on 11" rims with the same offset F and R. I can't answer your question though because I wasn't able to run any tracks I had ran previously with the stock wheels/tires before I moved and got the square setup. I do run a very small spacer in the front mostly to be able to run more camber...and I have camber plates...LOL.
07-28-2016, 10:43 AM | #8 |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
I run a square-ish setup - Z/28 wheels with 305s at all for corners. It does a great job of reducing understeer and makes it easier to rotate the car using minor throttle and brake inputs, but I wouldn't recommend it to track noobies - what is "neutral" at lower speeds can become quite a handful at higher speeds. There is significantly less margin for error with this setup.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
07-28-2016, 10:58 AM | #9 | |
