Old 08-04-2016, 10:51 AM   #1
camarogreen
camarogreen's Avatar
Drives: camaro
200k Camaro headgasket replaced
Good morning everyone,
Have a 2011 2lt Camaro with 200k miles (yup, lots of highway driving and endless joy rides), and looks like i'm in uncharted waters for this one. I was driving home on a hot 100 degree day been noticing that my temp seemed to be a little high (had AC on and was in a little traffic, but was moving at a good speed), say 232 (before the stat kicked in and it lowered back to ~225). All of a sudden I hear the alert bell sound and say the temp was too high (the temp was pegged on High), pulled over and everything looked fine, fan was on, no leaks,etc. To make a long story short had my shop replace the water pump and stat (both looked clean and new yay .) but when that didn't help they checked for a bad headgasket and sure enough it came out positive. The car never ran hot was always cool (within its range) so I was a little surprised. After doing some research I found that in Maryland there have been 7 cases of 2011 V6 Camaros one at 55 and the other 6 having mileage in the 100k+. Finally, this morning I heard back from my local shop that is repairing the car and sure enough there was a small leak on the passenger side. Just wondering if anyone else have heard of a similar issue.
When one camaro just wont do, its time to call: The Green Horent
camarogreen is offline   Reply With Quote
Old 08-04-2016, 11:27 AM   #2
TooCool5
TooCool5's Avatar
Never hear of the Head Gaskets failing. You may be in uncharted territory at 200k+.
Just curious, How long did the timing chains hold up?
Old 08-04-2016, 11:43 AM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Nice to see those high miles. I'm curious as well about the timing chain. I'm around 136k, no trouble so far.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-04-2016, 02:48 PM   #4
camarogreen
Drives: camaro
No trouble yet on the chain. But I would assume that they should be good till about 300k. This is the first major problem Ive had with the car besides regular checkups. But. on the Brightside she still looks good for a 200k car lol
Old 08-04-2016, 03:34 PM   #5
Dblock5
Dblock5's Avatar
Drives: 2010 Camaro LS
You must have a 2011 that was made after they beefed up the chains haha. But regarding your head gasket, never heard of them leaking before.
Dblock5 is offline   Reply With Quote
Old 08-04-2016, 07:51 PM   #6
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Haven't seen any yet, if you haven't had overheating problems before it's a bit strange. 232 seems pretty high, in fact 225 is too high compared to my engine. my coolant temp never goes about 190.
just make sure you go to a good shop, if you haven't then you should change out radiator hoses, thermostat, radiator cap. make sure there's nothing else causing overheating that made the head gasket go bad in the first place
TommyTheCat is offline   Reply With Quote
Old 08-04-2016, 10:30 PM   #7
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Wow and here I have a blown Camaro at 50k miles.....
Never heard of the gasket issue before but considering the milage thats not too baf
CAMARO
Old 08-05-2016, 10:06 AM   #8
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
I got 94k on mine with an ipf supercharger and im still on the stock timing chain as well as stock gaskets..i have always changed the oil at 3k miles and always ran good oil.. thats what i was told that causes the timing belt issue was not using a good oil and going over the recommended miles..
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 08-05-2016, 12:58 PM   #9
TooCool5
TooCool5's Avatar
Seems to be the solution for the 10's, 3k oil changes like I always did on previous cars.
For me that is about 10 months driving (not bad).
Old 08-09-2016, 11:25 PM   #10
camarogreen
Drives: camaro
yup 2011, I heard a lot about that model year having gasket issues around 90, 100k and 150k. We a few Camaro in that model year have issues, hope to get her back this week, the shop is treating me very well just waiting for everything to be put back together
Old 08-17-2016, 11:35 AM   #11
dfi1120
dfi1120's Avatar
Drives: 2010 camaro rs
I'm just about to hit 195k on my 2010 an ever herd of this either maybe I need to do a little inspection on engine it's due for a radiator flush
dfi1120 is offline   Reply With Quote
Old 08-18-2016, 12:52 PM   #12
camaro2ss/rs
Drives: 2ss/rs
wow you guys really got your moneys worth on this car... i have my car 6 years and have 24.920 on the clock... good for you guys mine is also a 2011 SS
camaro2ss/rs is offline   Reply With Quote
Old 08-18-2016, 02:26 PM   #13
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Depends on the car. Headgaskets on our 2004 Land Rover are considered a maintenance item about every 80K miles. Ours lasted about 100K miles. Usually its best to replace both sides rather than just one since the engine tear down cost is high. Its also not a bad idea to get the heads checked for worp, and finally you may want to get the valve guides replaced.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
