09-29-2016, 04:41 PM | #1 |
Drives: 2010 SS RS Join Date: Aug 2009
3" exhaust for AGP tt
I was rearended yesterday and my exhaust got messed up pretty good. I have mbrp 3" exhaust on it now and was thinking about getting something else. I like the sound of it but figured since I need a new exhaust I might go with something a little louder.
It was loud enough when I had headers on it, now that I have turbos they quieted it down. I listened to a lot of different sound clips but can't really tell what's louder. I like loud just not insane deafening loud. If you have any suggestions please let me know. Thanks |
09-29-2016, 04:46 PM | #2 |
Magna flow seems popular.
Nick
Corvette Z06 -1200ish rwhp |
09-29-2016, 05:30 PM | #3 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Corsa or Stainless Works offer a full 3in
09-29-2016, 05:32 PM | #4 |
Drives: 2010 camaro ss Join Date: Jun 2010
Add a cam and just get a muffler shop to fab up a straight piped exhaust. My buddy has this and its louder than my header cam supercharged as with Corsa exhaust
09-29-2016, 06:04 PM | #5 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
I run the Kooks 3" on mine. Not too bad.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
09-29-2016, 06:07 PM | #6 |
Drives: 2013 ZL1 Join Date: Jan 2015
12" dumps off the turbos, save weight and gain volume!
2013 A6 ZL1
09-29-2016, 08:12 PM | #7 |
Too much is never enough!
My Magnaflow, is tame at idle and cruising, and a beast at WOT.
09-29-2016, 10:46 PM | #8 |
Drives: 2011 2SS/RS (M6) 427 Twin Turbo Join Date: May 2008
Had stainlessworks 3in, ended up going straight piped. The turbo sounds come through so much more now it sounds insane!!
2011 Camaro 2SS/RS ERL 427 M6 TT -AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler |
09-29-2016, 10:58 PM | #9 | |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
Corsa 3" on my car, I like it but can only compare it to the factory NPP exhaust and it sound much better than that did IMO.
My car has Corsa modified with 3" v-flange to adapt to the turbos directly, which made it easy to R&R. FYI my car picked up 0 rwhp and 0 rwhp torque removing the 2.5" neck down between the 3" Corsa and the Turbos.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
09-29-2016, 11:58 PM | #10 | ||
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
AGP TT 807whp 811wtq 13.46psi E85+methanol
09-30-2016, 09:41 AM | #11 |
Drives: Twin turbo G8 GXP Join Date: Dec 2012
Why do people think louder is better? Annoying the 99% of the population that doesn't care about cars just makes the rest of us look bad.
09-30-2016, 09:48 AM | #12 | ||
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
09-30-2016, 11:23 AM | #13 |
Thanks guys. I'm leaning towards stainless works 3". I have the factory gfx and I see stainless works has tips that will fit.
09-30-2016, 01:55 PM | #14 |
Don't let the tips be the "be all end all". I have the factory gfx as well. If there is a particular sound you are looking for get the setup you want and buy the MBRP tips and have a local shop weld them on. That what i did.
