#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
BeckyD @ James Martin Chevy
Old 11-13-2016, 04:52 PM   #1
samsumon
Drives: 4 wheels
Infotainment screen won't turn on - thoughts?
FIXED! Pulled the trunk fuses! Thanks!
samsumon is offline   Reply With Quote
Old 11-13-2016, 05:17 PM   #2
SSSHYBOY
Drives: 2SS convertible, black,black
My thoughts; 7 AM ..Tomorrow... Dealer
A little known fact. Women with extra pounds, tend to live longer than men who mention it.
SSSHYBOY is offline   Reply With Quote
Old 11-13-2016, 05:20 PM   #3
samsumon
Drives: 4 wheels
If i wasn't getting my iphone screen replaced, I would lol... My luck with screens is great. But i'll call first thing in the morning.
Old 11-13-2016, 05:42 PM   #4
Keifer
Summit White 2SS
Keifer's Avatar
Drives: 2017 Summit White 2SS, 2018 Tahoe
Do you still have audio (radio)? Can you hear the seat belt chime? If you have radio, can you adjust volume from the steering wheel controls?
____________________
Keifer is offline   Reply With Quote
Old 11-13-2016, 05:48 PM   #5
dmj25
dmj25's Avatar
Drives: 2016 Camaro SS A8 Red Garnet NPP
Same thing happened to me. I took out the fuse for the radio and let it sit for several minutes and put it back. It's been working fine ever since.
dmj25 is offline   Reply With Quote
Old 11-13-2016, 07:48 PM   #6
JFM-jr
JFM-jr's Avatar
Drives: 2016 Camaro 2SS
Its in the fusebox in the trunk. Position is "F16 DISPLAY" pull the fuse wait 10 seconds and plug it back in and you should be good. Avoids a trip to the dealer but there is an update thru GM that eliminates this software issue. I just cant be bothered going in for this ill wait until In need something else.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 11-13-2016, 08:11 PM   #7
samsumon
Drives: 4 wheels
Thank you, will do it tomorrow. I need to go into the dealer for an oil change regardless, but I'll do this in the AM.
Thanks
Old 11-14-2016, 01:43 AM   #8
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
This happened to me the other evening, literally the night before I was going to take my car in for round two of a rear deck/speaker problem.
The display was lit, but solid black, the radio was working, and pressing randomly on the screen produced the sound of menu interactions.
The best info at the time suggested disconnecting the battery for ~10 minutes, and doing this cleared up the issue. I have decided to drive the car for another week before taking it back to the dealer, just to see if this becomes a habit.
Oil Man is offline   Reply With Quote
Old 11-14-2016, 05:52 AM   #9
samsumon
Drives: 4 wheels
Where in the trunk is the fuse box? i know where to find it under the hoods.
Old 11-14-2016, 06:05 AM   #10
dmj25
dmj25's Avatar
It's underneath the trunk mat. It's going to be to the right and there's a plastic cover you have to remove to access the fuses.
Old 11-14-2016, 06:18 AM   #11
samsumon
Drives: 4 wheels
I just looked and I don't have any 16 numbered fuses, thoughts?
Old 11-14-2016, 06:22 AM   #12
dmj25
dmj25's Avatar
There are two fuses to the far bottom left by themselves. The radio fuse should be 15 and should be blue. (2nd one from the bottom)
Old 11-14-2016, 08:24 AM   #13
JFM-jr
JFM-jr's Avatar
On the inside of the fusebox lid is a diagram that shows fuse positions. Look for "F16 Display" on the diagram and match it to the corresponding position in the actual box. Im not sure the amperage of the fuse i just remember the physical location designation and description labeled on the diagram.
Rotofab
11.0@124.9
Old 11-21-2016, 12:53 PM   #14
MarkZ
MarkZ's Avatar
Drives: 2016 Camaro RS 2LT
This literally just happened to me.
  • Volume only works from steering wheel
  • No xm channels being displayed but it plays them just fine. It displays channel 0 and radio ID?
  • Fm channels, plays 95.5 but when you hit 97.9 it goes to the different channel but display still says 95.5
  • Cant change interior light color.
  • Blue tooth is just all messed up. connects but never plays any sounds.
Going to reset the 16 fuse now, and see what happens.
Mark
MarkZ is offline   Reply With Quote
