01-03-2017, 05:44 PM | #1 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Spec Clutch?
Anyone here use a spec clutch? My current power is about 425tq at the wheels, so I was looking at a stage 3. The most I plan on doing in terms of making more power is the heads, no FI.
I tried looking around on the forum, but I couldnt find anyone's opinion on them. I plan on getting a machine shop to cut my current flywheel (if it can be) and using spec's slave upgrade. I've never gone to an aftermarket clutch so I dont know what to expect in terms of leg feel... I do know that since we have a hydraulic, it shouldnt be that bad right? My reason for the upgrade is because I am having a hard time from a dig with the stock clutch... just seems to burn it up when I try or suck the pedal to the floor, but every where I see, the best technique to the dig is to be around 4500-5000 rpm (power band) and to slip the clutch some. I would appreciate some inputs. Budget is around a grand |
01-03-2017, 05:52 PM | #2 |
Spec is like 30 minutes from me.
If they offer a light pedal option buy it. Its rock hard without it. I've been in 2 with a Spec. Very hard pedal.
01-04-2017, 03:00 PM | #3 |
Thanks bo. I think I'm going to get their stage 3 once in a month or so and see about that light pedal option.
Apparently I need to get their flywheel for it and I guess its a little lighter, but the overall package is 600 bucks so far so I'm happy |
01-10-2017, 10:12 AM | #4 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Currently deciding between a Spec Stage 2/2+ or Mantic ER2
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-11-2017, 07:14 PM | #5 | |
I even mentioned about slipping the clutch some for our launches and was told the Stage 3 can be slipped a little bit. Of course theres a difference between burning at redline and slipping at optimal launch rpm. I'll include the costs of everything too. So far looking at 650 for a flywheel, clutch kit, and light pedal option. You need a flywheel with their clutch kits unless you buy the "stock kit" which costs the same as if you bought their normal one with their flywheel. Staying steel with the flywheel too, but I believe its a couple pounds lighter. I'll install within the week of getting it probably |
01-12-2017, 04:27 PM | #6 | |
2010 2SS/RS
01-15-2017, 10:50 PM | #7 |
DD, but I bring it to both the strip and roadcourse. I dont mind DD'ing it even if its a little less comfortable. Gives me motivation to get a real DD haha
01-31-2017, 01:35 PM | #8 |
Drives: 2013 Camaro SS LS3 Join Date: Jun 2015
I have a 3+ with about 5k HARD miles on it with a cam full bolt ons and 20" drag radials. So far so good. It's supposed to handle around 900 ft/lbs of torque so I'll let you know how it does on nitrous this year when it warms up. Broke my passenger side axle last year with it at the track so I'm assuming it's doing it's job.
Pedal feel is a little stiffer than stock, but I guess it is user preference whether you can deal with it or not. I DD mine in the spring through summer and it wasn't a big deal for me. I've got to pull my trans due to a loud screeching sound (thinking it's either the pilot or throwout bearing) soon. I'll let you know if it still looks good then.
Romans 5:8 But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. -Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20. |
01-31-2017, 02:04 PM | #9 |
Drives: 2012 ls3 Join Date: Feb 2014
Thanks for your input I'm currently saving for the 3+. You were on your drag radials when it snapped.
01-31-2017, 02:41 PM | #10 | |
Sent from my VS990 using Tapatalk
01-31-2017, 03:05 PM | #11 |
I've done that. Car didn't even trip the prestage bulbs lol. I thought it jumped out of gear at first.
02-04-2017, 08:31 PM | #12 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
Fingers on pressure plate fail. Way overrated on hp rating
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
02-05-2017, 03:13 PM | #13 | |
03-29-2017, 12:00 PM | #14 |
Drives: 2012 Camaro 1LS w/L99/TR6060 Join Date: Dec 2012
I'm currently running Spec stage 2. Full package. Flywheel, PP, disk. I'm loving the feel. Definitely a stiffer pedal, but not unbearable. And having a short through it's even more awesome. Loving this motorswap, not regretting one bit of it.
