Old 07-02-2008, 08:00 AM   #1
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Question Will the V6 have DBW or a good old fashioned cable throttle?
I'd guess that if it's the DI V6, it will be setup the same way as the CTS. How is the CTS configured?
If the CTS has DBW, does it at least TRY to pretend it's a cable throttle, or does it try to guess what you really want rather than obey your foot?
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 07-02-2008, 08:23 AM   #2
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
ANY newly developed from the ground up car will have the latest tech, its just easier to do things, engineering is already done.
That said I believe the CTS is DBW and I EXPECT the camaro in all trims to be DBW.
DBW is a good thing it opens soooo much more tune-ability, just like EFI over CARBS.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 07-02-2008, 09:54 AM   #3
z28collection
waiting for 5th gen
z28collection's Avatar
Drives: 99 z28 6 speed, 81 z28 auto
DBW
when i drove the dodge srt cars at the srt track experience the dbw that they used sucked. it takes control away from the driver and if i can change that on my camaro i will.
speed kills-drive a ford and live forever
http://www.myspace.com/ashleyjfowlkes
z28collection is offline   Reply With Quote
Old 07-02-2008, 11:43 AM   #4
The_Blur
Moderator
The_Blur's Avatar
I think we'll all be satisfied with the system in the Camaro. As time goes on, these advanced systems will be more sensitive to driver control, especially in performance-oriented cars. I'd expect GM to have developed a very sophisticated system to support the hype over the new Camaro.
warn 145:159 ban
Old 07-02-2008, 12:43 PM   #5
theholycow
theholycow's Avatar
My 2008 VW has DBW throttle, and it's rather inconsistent, apparently trying (and failing!) to guess what I really want rather than what my foot did. It's kinda tough to rev-match...sometimes I hit the pedal and it doesn't respond at all, other times with the same pressure on the pedal it jumps up to 6000rpm. Then there's rev hang, which is stuck throttle's bastard brother...
Old 07-02-2008, 03:29 PM   #6
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
That's b/c it's a VW and not a Chevy.
Chevyrocker is offline   Reply With Quote
Old 07-02-2008, 07:02 PM   #7
theholycow
theholycow's Avatar
Hrmph. German engineering my ass...
Old 07-02-2008, 07:45 PM   #8
SoFlaZ
SoFlaZ's Avatar
Drives: 2013 SS LS3
I hope there is a way to tune the throttle to exactly what my foot is doing if it isn't already like that. My experience with an auto cobalt and dbw was horrible, it took to my guesstimate almost 2 seconds to shift down a gear and rev when i step on it! With a shift kit it might be better though.
SoFlaZ is offline   Reply With Quote
Old 07-02-2008, 08:20 PM   #9
Grape Ape
Drives: 96 Bronco w/ a 5 speed
You can count on all DI motors being DBW. When cruising they go into an "ultra lean burn" mode where they open the throttle pretty wide and slightly reduce they amount of fuel injected (for the load compared to port injection) to reduce pumping losses.
I don’t believe there will be much you can do to convert it to a mechanical throttle, but I’m sure the tuners will do their best to correct any short comings.
I believe we have been promised an “aggressive throttle map”.
Grape Ape is offline   Reply With Quote
Old 07-02-2008, 08:25 PM   #10
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
I personally like having a throttle cable, BUT I'm not going to write the camaro off until I've driven it, and I'll probably buy it anyway.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 07-02-2008, 08:31 PM   #11
theholycow
theholycow's Avatar
NICE! That is something I was hoping for but it was sounding like that's not the case. I'm glad to hear it is. That's like hypermiling without the controversial behaviors!
I'll settle for consistent.
Old 07-02-2008, 10:10 PM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
thats what I always say. And I am an engineer in training.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-03-2008, 09:36 AM   #13
SoFlaZ
SoFlaZ's Avatar
Drives: 2013 SS LS3
They might as well call German engineering impossible engineering. I know how to do basic maintenance on cars but I will not TOUCH any friends car that is from Germany, no no no. My old porsche 944 was a nightmare, and that was 1980's technology!
I know it WILL be DBW, all I want from the it is to move with my foot exactly as I move it like an "electric" cable throttle, while still maintaining its fuel saving abilities, traction control, and all that other stuff.
Old 07-06-2008, 01:48 PM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I've never encountered a problem in my Cobalt with Drive-by-wire...Whatever my foot says, the throttle does. No hesitation, no guessing. So I'm not worried in the least.
And for what it's worth, the base Corvette, Z06, AND ZR1 are all Drive-by-wire...............
so are we going to have a throttle cable? pearsonmx6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 12-27-2007 12:40 AM
Edmunds.com review of Holden Commodore... good info. LSxcellent General Automotive + Other Cars Discussion 6 07-23-2007 06:49 PM
