05-04-2017, 10:58 AM | #1 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Z28 UCA bushings from GMparts direct - need clarification
So my order from GMpartsdirect direct finally arrived...after they said that one of the bushings was unavailable...and I requested in writing that the order be cancelled....and I now have this dilemma. I have researched the web and C5 trying to get clear pics of BOTH left and right bushings...I have read that both bushings are solid but all the pic's show the right is solid and the left has some voids...what gives...I have also read where GM will fulfill an order and sends out either a ZL1 or 1LE instead...so what do I have?
I want to get these installed and hopefully get to the strip and see how my latest upgrades work in the Q. TKS in advance!!!! peace out...
05-04-2017, 11:08 AM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
I think Pete from JPSS will know the correct answer to this.
Try contacting him. http://www.jpssonline.com/shop/z28-r...rm-bushing-set Sent from my SM-G935V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
05-04-2017, 11:38 AM | #3 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Yep - Pete hooked me up. Both of mine are solid, no voids.
Make sure you get this fixed before you put it on and you will be happy!!
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
05-04-2017, 12:40 PM | #4 |
That's what is was 'fraid of...dang-it!....wonderin if it's goin to be worth the f'kin headaches gettin this straighten out...tks...
05-04-2017, 12:48 PM | #5 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Yea mine were both solid as well.
More to come. |
05-04-2017, 07:13 PM | #6 |
Drives: 2012 Camaro SS Join Date: Oct 2016
Same both solid, Give pete at JPSS a shout and I'm sure he can get you what you need super quick to.
05-05-2017, 08:09 AM | #7 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Agreed on all the above I got mine from Pete, there was issues of a right side being put in a left PN box or vice versa for awhile, haven't seen your issue. Pete can take a solid bushing an flip it around and restake the bushing so it fits right.
Orange Krush II
