05-14-2017, 09:33 PM | #1 |
Purchasing Clutch/Flywheel need help
Hello everyone,
I think it's about time to upgrade on the clutch and flywheel. I noticed the other day while giving a few runs that my clutch pedal bottomed down to the floor and wouldn't come up. I've researched a few reasons why that might happen and because of the amount of torque I'm generating It's safe to say a new clutch will be in the near future. I've heard Monster, McLeod and ACT are some choices but from personal experience what's in your rides to a similar application that my car has?
Maggie heartbeat SC, 3.40 Pulley, ZL1 FP, ADM FPCM, ZR1 3 bar map sensor, ID1050x injectors, Rotofab CAÍ, BBK Long tube headers, BBK HF cats, axle back loudmouth exhaust. McLeod RST Twin Disk Clutch, Tuned by Ted Jannetty,
Tires: Nitto NT555R |
05-14-2017, 09:48 PM | #2 |
Drives: rumble bee,2SS 6sp Join Date: May 2009
No to act. Mine is 2 times harder to push down and slips with just cam. Looking at lt1-s as another replacement
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
05-14-2017, 09:49 PM | #3 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
Im twin turbo at 625rwhp 600rwtq and I love my Monster LT1-S triple. I was at the strip last week and did 20 runs slipping the clutch out on the launch and wot shifting and never had a single issue. Plus it drives just like stock. IMO its smoother than stock.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
05-14-2017, 09:49 PM | #4 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Twin-plate clutch with Hendrix, Monster or McLeod would be good for your future.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
05-14-2017, 10:19 PM | #5 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Just put the RXT in mine yesterday.
05-14-2017, 10:22 PM | #6 |
Easy install. Pedal is lighter and drives like stock
I read every post on just about every clutch. Even talked to the manufacturers themself. McLeod was more than helpful and responded within 3-4 minutes. Others not so much....Heck, I still haven't received a response from one you mentioned..... |
05-14-2017, 10:37 PM | #7 | |
05-14-2017, 10:38 PM | #8 |
McLeod is probably the way I want to go. I look to adding more power down the line and they have a good name. Thanks for your input and nice set up on your ride.
05-14-2017, 11:41 PM | #9 |
