Old 10-29-2009, 02:48 PM   #1
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Would like to do a compilation of L99 Header, CAI & Tune dynographs
Hey guys,
I am trying to see if we really will run out of steam at around 360rwhp & 380rwtq on the L99 w/ only Headers (ok if it has a axleback as those are really only for sound), Cold Air Intake, and a Tune. Must be on a Dynojet SAE corrected so we can compare apples to apples. The Data I have so far suggests this.
1. GMRULZ: 362rwhp 381rwtq. ARH 1 7/8 headers high flow cats, stock mufflers, ADM race intake, CarolinaAutomasters tune. Dynojet SAE .
2.Tanner 363rwhp 379rwtq. ARH headers w/ cats, borla axleback, Rotofab CAI, tune. Dynojet SAE
3.Number_9 365rwhp 382rwtq ARH 1 7/8 headers, ADM/Magnafloz z-pipe, ADM Race CAI, ADM tune. Dynojet SAE
4.Ted Jannety 370rwhp 387rwtq Kooks 1 3/4 headers, Kooks full exhaust, JRE tune, Cold Air inductions CAI(**NOTE Ted`s is on a Superflow Dyno some may not wish to include it for apples to apples but I want to leave it for reference**)
5. IPS Brandon 361rwhp 376rwtq Stainless works 1 7/8 headers, LMR CAI, IPS tune, stock axleback.
6. SGOS252382 350rwhp, 360rwtq Kooks 1 7/8 headers w/ cats, LMR CAI, Magnaflow exhaust, Formato tune
7. melson 375rwhp 381rwtq ARH 1 7/8, magnaflow 3 inch catback, ADM CAI, ADM Protune
So far on the dynojets sae corrected horsepower is all w/in 4rwhp and torque w/in 6rwtq.
Here is my graph to start:
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-29-2009, 03:03 PM   #2
toehead93
Drives: 2014 2SS/1LE
I have headers in the garage. Once I get my Vararam installed I'll do the headers and get it dyno'd. I won't be able to get a baseline dyno the same day though for the headers, I will for the Vararam kit though.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-29-2009, 03:06 PM   #3
GMRULZ
GMRULZ's Avatar
Thanks man! for this compilation I`m not worried about a baseline, just want to see what headers, intake and tune (needs to have at least these 3 mods) will make on a L99 and see if everyone hits the same wall or not. Only stipulation is Dynojet SAE corrected numbers.
Old 10-29-2009, 03:18 PM   #4
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Were did you get your car tuned? My tune only L99 only made 330 rwhp at a Mustang Shop over in St Pete Fl (in 94 degree temps with high humidity).
But my car runs strong. It was trapping 108 - 109 mph at BMP a few weeks ago. In cooler air (like the guys run in up north), it would have been trapping in the 111 - 112mph range.
I've got Kooks' 1 3/4 Heades on order. When I get the headers I'm going have it re-tuned. I'm hoping from 12.4 - 12.5s @ 112 mph with
CAI, LT Headers, GMPP mufflers, tune.
Old 10-29-2009, 03:25 PM   #5
toehead93
My L99 was the test car for Diablo Sports so I have arranged to see them again when I get the VR intake. Mine was also tuned in the middle of summer with high temps and humidity.
After DS tests and tunes th VR kit I'm adding my Dynatech headers. I'm expecting the same track performance you are. My SAE corrected tune only is at 343rwhp so I'm hoping to be close to be at 365-370 with the intake and tune plus +25-30 with the headers. Maybe I'm too optimistic?
2010 2SS A6 - sold.
Old 10-29-2009, 03:31 PM   #6
GMRULZ
GMRULZ's Avatar
If the it was a dynojet and was SAE corrected it wouldn`t matter too much on the heat unless the computer was pulling timing due to the heat as SAE correction makes everything else even no matter the temp.
I`m hoping for 12.5`s at 112 also in good air. We shall see.
Toehead,
I`m doing this mainly to see if we hit a wall on these due to the stock camshaft. So if you hit 370+ish on a dynojet SAE corrected then thats not the case. I have found 2 other L99`s and they put down almost identical numbers w/ similar mods and one added a FAST intake and only saw 3rwhp and 4rwtq. I`m not sure the L99 will make more power w/ out a new cam or forced induction or nitrous. Also having heard this might be the case from my tuner and Andy from ADM in Camaro1`s fast thread.
Old 10-29-2009, 04:51 PM   #7
Longhorn SS
Longhorn SS's Avatar
Drives: 2010 IOM Camaro SSRS L99
I have a Roto-Fab CAI now. Am installing ARH 1-3/4" LTs w/cats tomorrow AM and getting tuned at LMR tomorrow afternoon. Will post my dyno afterwards.
2010 Camaro 2SS/RS - Roto-Fab CAI, ARH 1-3/4" LTs w/cats, LMR tune, KW V3 coilovers, Pfadt F&R sway bars, end links, rear trailing arms, tie rods, solid subframe bushings, HPS brake pads
Longhorn SS is offline   Reply With Quote
Old 10-29-2009, 06:03 PM   #8
GMRULZ
GMRULZ's Avatar
Thanks Longhorn SS!
Old 10-31-2009, 11:25 AM   #9
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
So where are these dyno graphs?
StlRomAniaN is offline   Reply With Quote
Old 10-31-2009, 10:19 PM   #10
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Here is one of mine....the 349/367 is Headers only...no CAI.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 11-01-2009, 05:34 AM   #11
GMRULZ
GMRULZ's Avatar
Thanks! Did you have a tune?
Old 11-01-2009, 07:21 AM   #12
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Tune and Headers...my shop's dyno is a little conservative also, 500 miles on the motor at the time.
Old 11-01-2009, 10:17 AM   #13
Tanner
Tanner's Avatar
Here is mine with ARH long tubes with X-pipe and high flow cats, Borla S Type Axle Back and Roto-Fab CAI. She came out with 363 RWHP and 379 RWTQ.
2SS/RS Victory Red / painted White Rally Stripes - 6 Speed Automatic with Tap Shifter
Sands - Surprise
Tanner is offline   Reply With Quote
Old 11-01-2009, 10:25 AM   #14
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Nice job Tanner, How are the boy's.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3652 08-17-2023 02:50 PM
Another L99 Dyno tune (with headers and CAI) pcmforless Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 02-26-2011 06:36 AM
Vector Motorsports PowerFlash Tune & Roto-Fab CAI Videos ralyrat Tuning / Diagnostics -- engine and transmission 35 03-13-2010 09:38 AM
GM High Tech Performance Magazine's L99 Tune - +81 ft lbs at 3500 rpms! SGOS252382 Tuning / Diagnostics -- engine and transmission 52 09-30-2009 11:31 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
