07-17-2017, 07:33 PM | #1 |
Drives: 2011 Camaro LS Join Date: Sep 2008
2010 SS can I run same tires on all corners?
I need new tires, can I run the same size, either fronts or rears on all 4 corners?
07-17-2017, 11:08 PM | #2 |
Drives: 2013 Camaro 2SS Join Date: Aug 2013
Depending on the wheel, yes. Make sure the wheels are the proper width for the tires.
http://www.camaro5.com/forums/showthread.php?t=62838 |
07-18-2017, 05:31 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
What wheels are on the car?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-18-2017, 05:45 AM | #4 |
Stock 20" Pirellis
07-18-2017, 05:47 AM | #5 |
Should have been clearer.... I want to run same size on stock rims. I know the rear stock is a little wider so can I run either the front size on all 4 or the rear size on all 4?
07-18-2017, 06:07 AM | #6 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
You could physically mount the front size on the rear, but you shouldn't. Try to buy a second set of front rims to put on the rear and then go to a square set up.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
07-18-2017, 10:42 AM | #7 |
Go search the member classifieds. Always somebody selling stock rims on the cheap. Go find either a pair 8"or 9" rims....then you can safely/properly mount same size all around.
07-18-2017, 01:00 PM | #8 |
Instagram: Sangstah
The proper way to get same size wheels front and back and same size tires, but I don't see any problem with running all 4 same size tires it will just be staggered and fit different.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
07-19-2017, 04:17 PM | #9 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
245/45-20 on 20x9" is a max-wheel-width setup and just as legitimate as what Chevy did on the 5th gen 1LE (285/35-20 on 11") - and for that matter what Ford did with the 2008 GT500 before that (255/45-18 on 9.5", which I've done myself). IOW, there's plenty of precedent even at the OE level. Appearancewise, it's not 'conventional' so many people don't care for what it looks like, and you don't get as much scuff protection for the wheel. Going the other way - 275/40's on 20x8 - is not recommended. 20x9 for that tire size is min-recommended as it is. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
07-23-2017, 09:37 AM | #10 |
Drives: 2014 2SS blue Join Date: Jun 2016
No
The car is setup to handle safely for the average driver. That means it understeers (plows) so a driver will slow down if he exceeds the cornering capability of the car. If you run a square setup, the handling will shift toward neutral or even oversteer. These two handling characteristics are much more prone for an average driver to lose control than understeer. That why virtually all common passenger cars are setup to understeer.
07-23-2017, 10:14 AM | #11 | |
Drives: Miss Con Ception Join Date: Aug 2016
I have 275/40X20 all around with 9" and 10" wheels and it still understeers. Not as bad as it did with the 245s, but the front end still slides first.
2011 1SS/RS LS3 CGM
07-23-2017, 11:54 AM | #12 | |
07-23-2017, 01:40 PM | #13 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
I think max on the 8" fronts is 255mm.
You need 2 more rear rims to go square. Why not just go 255 on the fronts and max the rear at 285? You get a bit more tire at both ends and your within spec for rim with and tire width.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
07-23-2017, 02:02 PM | #14 |
Banned
Drives: Camaro Join Date: Mar 2013
The SS comes with 275 on the rear and many put them on the front, so yes.
The question should be about wheels. Get the appropriate offset for front and rear as they are different. |
