11-14-2017, 03:34 PM | #1 |
Drives: 2017 Chevrolet Camaro 2SS Join Date: Oct 2017
GM wireless charging upgrade for iPhone X & 8?
So I’ve been reading that Apple’s IPhone 8 and IPhone X are not compatible with wireless pads in GM vehicles (except for a select few of 2018 models, which Camaro is not one).
I have a wireless pad in my 2017 Camaro 2SS and I ordered an IPhone X, but did so before finding this out. Hmm. So the topic here in this thread, is do you think GM will make an upgrade kit that we can install or the dealer can install that will work with IPhone X and IPhone 8? Millions of people will have these phones, I don’t see how GM could not offer an upgrade fix for GM vehicles with incompatible wireless pads. Thoughts? |
11-14-2017, 03:56 PM | #2 | |
Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
I just don’t see GM doing this. They probably have attitude that it’s not their issue that Apples phone doesn’t work. My iPhone 6 works with a Q case I got from Amazon. I would think or could see an outside vendor like Ofer at gen5diy doing a fix, maybe and it’s a stretch. Sent from my iPhone using Tapatalk
Never grow up, it's a trap!
11-14-2017, 04:03 PM | #3 | |
11-14-2017, 04:29 PM | #4 |
I think I might have found a solution. I found a video on YouTube of a guy with an IPhone X and a GMC and he opened the charger, removed the receiver piece and put it back together and it charged his phone. Probably would work the same on a Camaro. Take a look:
https://m.youtube.com/watch?v=u29igTCTdLM https://m.youtube.com/watch?v=3AZKlTDnqsU Last edited by Rob Camaro; 11-14-2017 at 04:46 PM. |
11-14-2017, 04:51 PM | #5 |
Drives: Sold Join Date: Mar 2017
So, he admits he doesn't know what it does, but speculates and just removes a piece of tech that's actually plugged in to the unit and then is good because it works?
You can remove a fused link from an electrical circuit and it will work, that doesn't mean it's a good idea. Qi and PMA, while similar, work in different frequencies. That piece could be some sort of attenuator or frequency barrier put there intentionally to block certain ranges it's not certified to emit or work on. Sure, it could be a booster to help it push the range of the signal through the plastic and up in to the cradle in the console top, but if he's not an EE/RF person or has a how-to written up with solid data, this is speculative and could lead to issue with the powering coils/system or damage to your phone. Personally, I wouldn't do this to my car w/o knowing more about the design of that charging system. |
11-14-2017, 04:53 PM | #6 |
Drives: 2018 ZL1 Join Date: Oct 2011
I just can’t see in everyday driving being able to actually keep my phone on that charging pad . But if you end up doing that feel free to let us know how it worked out.
2018 ZL1…Many mods to come
11-14-2017, 05:54 PM | #7 | |
11-15-2017, 02:22 PM | #8 |
Drives: 2016 Camaro 2ss Join Date: Feb 2016
I am interested in this as well, just got the X and want to be able to charge my phone using the charger I've already paid for!
11-15-2017, 02:27 PM | #9 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
You guys talking about that mini change dish in the backseat?
11-15-2017, 02:31 PM | #10 |
Given that I've had a Note 5 and now a Note 8.. Yep... It's just a small utility tray that typically only holds armour all or something else.
My GF has an iPhone8 and we were bummed on trying it on both our 16 SS and 17 ZL1 and neither worked. Even had the dealer look in to it to see if there was a TSB or something to where they could just change out the whole module... Nothing. It's not a huge deal for us as she uses CarPlay via cable and has a magnetic case clip on the driver's console vent and I don't much care, so I just plug in when needed. |
11-15-2017, 02:36 PM | #11 | |
/threadjack lol |
11-15-2017, 03:06 PM | #12 |
11-16-2017, 09:20 AM | #13 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
Has anyone had the console apart and seen if the charging unit can be changed? It might also be possible to deactivate what is there and lay over a newer unit powered off the console USB. These things are dirt cheap.
https://www.ebay.com/i/292166910585?chn=ps&dispctrl=1 |
11-16-2017, 11:18 AM | #14 | |
Drives: 2016 Camaro 2SS Join Date: Oct 2015
For me it was only a minor disappointment as you are required to plug the phone in for AA to work and you get a better quality charge out of that anyways.
Ordered: 2SS Nightfall Gray, NPP, MRC, navi, auto, low gloss black wheels, black bowties
TCFCB4 1000: 12/08/2015 2000: 12/08/2015 3000: 12/10/2015 3000: 12/12/2105 - TPW 1/11/2016 3100: 12/18/2015 - TPW 1/18/2016 3300: 12/23/2015 - TPW 1/11/2016 3400: 12/24/2015 3800: 01/19/2016 4300: 01/20/2016, 4200: 1/28/2016, 4300: 1/29/2016, 4B00: 1/30/2016, 4200: 2/7/2016 (train), 4800: 2/19/2016, 5000: 2/22/2016, 6000: 2/25/2016 |
Tags |
wireless charging |
