12-08-2017, 07:34 AM | #1 |
Drives: 2016 SS Join Date: Jan 2013
TH400 Swap W/Pictures
I dont get on the forums much anymore but have been asked by a few to start a thread on my th400 swap from a 8l90 A8.
Start off car is a front mount large frame turbo s476/92 Prior to port injection and holley hi ram out the hood lol Made great power till i got greedy and popped the motor, so am doing a built motor and decided to go ahead and do the 400 swap over the winter. Transmission is at a builder getting built Reverse Manual Valve Body Trans Brake Ultra Bell Bell Housing Circle D Converter Heres the 8 Speed Next to its replacement Had to build a bracket to bring the front of the new Hurst Quarter Stick Shifter up an inch and the rear up 2 inches. Bracket Bolts to the factory 4 bolts of factory shifter Will post more updates on the swap as soon as i have the transmission back from the builder.
12-08-2017, 07:53 AM | #2 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
Who did the turbo kit?
12-08-2017, 11:22 AM | #3 |
Aldo welds did The hotside. Rest was custom done by myself after his was deemed unacceptable
12-10-2017, 04:24 PM | #4 |
Drives: Camaro 17 SS Join Date: Jan 2017
Hey man. Thanks for starting this. I am one of the guys on FB that asked about you starting threads on here. It is looking good. Keep us posted. Watching here and FB.
12-11-2017, 05:56 PM | #5 |
Yes sir. Once everything on my builds i did was documented on a forum and I’m trying to make a comeback on that. What does everyone use for photo hosting? Cause photobucket isn’t working well for me anymore
12-16-2017, 08:01 PM | #6 |
Honestly I just upload them from my laptop. Is that a bad idea? And happy to see the thread.
12-16-2017, 08:24 PM | #7 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Just click the advanced button and use the paperclip to upload pics to the site.
12-17-2017, 08:40 PM | #8 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
What are you doing for gears in the rear?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
12-19-2017, 09:14 AM | #9 |
Drives: 2016 Camaro Join Date: Mar 2016
Nice. What flywheel do you plan on using? I've put glides in LS cars before, any idea if the LT uses the same parts? The last one that I did used a Hughes LSx flywheel and a spacer for the converter snout.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it |
12-19-2017, 07:13 PM | #10 |
Chris at circle d is building the converter to adapt to the factory flywheel.
As far as gearing. Will stick with the 2.77 until i do a 9” unless i come across a 3.73 diff reasonable
12-19-2017, 07:16 PM | #11 |
Th400 is back from builder.
12-19-2017, 09:27 PM | #12 |
More than likely will keep it in the 34-3600 range
05-19-2019, 07:58 PM | #13 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Damn thread went dead?
What ever happened?
12-01-2019, 09:32 PM | #14 |
Drives: 2016 camaro ss Join Date: Apr 2018
Whatever happened?
