Old 12-16-2017, 10:34 AM   #1
CamiLFX
CamiLFX's Avatar
Drives: 2014 Camaro LS
Intermittent chirping?
Hey! This is my first post, so I apologize if this could be put in a better sub-forum. Also, i've spent several hours in the search tab, so please don't tell me that i'm going to find an answer there. The situation is not similar to anything i've found in previous posts. Thanks!
I bought my gorgeous 2014 V6 Camaro (Manual) about 4 weeks ago with 59k on the odo. Since my purchase, i've noticed an intermittent chirp coming from the front end. It's most noticeable when pulling up near drive thru windows, and it only seems to happen when warm at idle, or when launching in first gear. The only way I can make the chirp happen on my own accord is if i bog the engine down when letting off of the clutch. However, the noise will appear on it's own if i'm sitting at idle without making any kind of input. At point, the noise would appear when closing the door or hood, or when simply pressing the brakes, which leads me to believe that something in the front is fairly loose.
Does anyone have any idea of what may be causing a sound like this? Thanks!
CamiLFX is offline   Reply With Quote
Old 12-16-2017, 10:37 AM   #2
CamiLFX
CamiLFX's Avatar
https://youtu.be/JfMhQBEqUcg
Here's a video of the noise being made
Old 12-16-2017, 10:38 AM   #3
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
I have a similar noise that's coming from the alternator.
blackswan is offline   Reply With Quote
Old 12-16-2017, 11:26 AM   #4
CamiLFX
CamiLFX's Avatar
I'll investigate. I hope that it's not the alternator. I'll be pissed if i have to dish out anything more than $200 on this. Guess that's what you get when you buy used.
Old 12-16-2017, 11:59 AM   #5
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Ok, just listened to your video, totally diff noise sorry.
Old 12-17-2017, 01:55 PM   #6
CamiLFX
CamiLFX's Avatar
https://youtu.be/b3-aCqsfcls
*Bump*
This is the worst case scenario. Movements like closing the door or hood initiate the sound. Someone please help me out before I dish out cash to the stealership. Just about any theory is helpful.
Old 12-17-2017, 02:52 PM   #7
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
A shot in the dark... but to me it seems like something is rattling/rubbing related to your exhaust. Thus the reason a mid-body vibration can make it occur. The actual rattling of it might be closer to the engine bay and downpipes though. Sounds kind of heat shield-ish in the first video.
Jazzzed is offline   Reply With Quote
Old 12-17-2017, 04:57 PM   #8
CamiLFX
CamiLFX's Avatar
The shop foreman at the dealership I work at (not Chevrolet) said the same thing. I got under it not too long ago and I couldn't find any place where the exhaust could be making any contact with anything that it shouldn't be. I'm going to go out and wiggle it around to see if I can recreate the sound. Thanks!
Old 12-17-2017, 07:09 PM   #9
CamiLFX
CamiLFX's Avatar
Looked around for a solid 45 minutes with the engine running trying to make the sound and it ended up being one of the shields just before the cats. Adjusted the clamp around it and voila. Issue resolved.
Old 12-17-2017, 09:34 PM   #10
Jazzzed
Jazzzed's Avatar
Nice
Old 12-19-2017, 01:08 AM   #11
stlsv6
Drives: 2012 Camaro Ls
Glad you got it fixed.
stlsv6 is offline   Reply With Quote
belt, belt tensioner, chirp, lfx
