03-20-2018, 02:45 AM | #1 |
Plugs and gap for corn
Ok so for a car making 1000whp what heat range plug and gap should one run for e85?
I'm currently running NGK 9s with a .020 gap
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
03-20-2018, 09:04 AM | #2 |
Drives: Camaro SS Join Date: Jan 2013
I'm running NGK BR7EF at .028 with no issues. I had them gapped to .030 and got spark blow out on one cylinder. haven't seen any issues at .028.
Fully Built 416ci / Procharger F1X / Century Built 4L80 / ZL1 Differential / Alky Control Meth /Circle D Triple Disk / ID1300s / Fore Innovations Return / Kooks Full Exhaust / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
03-20-2018, 09:33 AM | #3 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
BR7EF at .20 no issue
03-20-2018, 05:46 PM | #4 |
Drives: 2009 ZR1 Join Date: May 2010
BR7EF @ .024 with no issues.
03-20-2018, 06:55 PM | #5 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
Not quite 1000whp but i also run the BR7EF @.028"
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
03-20-2018, 10:01 PM | #6 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Same here. But gonna be soon enough!
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-21-2018, 07:50 AM | #7 |
Drives: 2014 SS 1LE Join Date: Apr 2014
BR7EF @ .028
