04-21-2018, 10:19 AM | #1 |
Drives: 2011 camaro 2SS Join Date: Apr 2017
Just 3.91 comment
I think it's insane that people are selling used 3.91 rear ends for $1,000 when at least where I live you can have a shop provide all the parts and labor and have all new stuff for $100-200 more.
04-21-2018, 10:23 AM | #2 |
USA-1
If you buy the 3.91 rear already done you can sell your old diff...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-22-2018, 05:44 AM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I went with new gears and glad I did. Setup is perfect zero whine.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-22-2018, 07:45 AM | #4 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
I spent right at a 1000 to get mine done .
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
04-22-2018, 07:53 AM | #5 |
Drives: 2011 camaro 2SS RS Join Date: Apr 2014
I bought a complete rear end from GM brand new for $1400 and still had mine to sell and it sold for $700 locally
04-22-2018, 08:29 AM | #6 |
Similar experience here.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
04-22-2018, 09:54 AM | #7 |
Drives: '23 LT1 A10 Join Date: Oct 2015
I paid 940 for a used 3.91. A new one when I was looking was 1500 or so. Most of the shops around me wanted to charge at least 900 for labor to swap the gears, plus the 450 for the gear set. So yes, buying a used diff for nearly 1000 is worth it considering you can sell your old one and make something back.
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
04-23-2018, 11:31 AM | #8 |
Drives: 2011 2SS/RS Join Date: Feb 2014
Can you still buy the 1le diff from factory? I was thinking about doing this, and just did some quick looking. Shows as "unavailable" on just about every parts website. I know the gear set can be bought, but if you can buy the whole chunk, its a relatively straightforward diy swap, as opposed to having a shop install gears in an existing diff
04-23-2018, 11:45 AM | #9 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Interested in 1 LE as well.
Aside from that. What else is required for the upgrade any ancillaries? Just the diff/final gear? |
04-23-2018, 12:50 PM | #10 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Just 3.91 comment
Isn’t the diff in the SS the same as the 1le if you just switch out the gears it’s exactly like the 1le, right? I read that somewhere. Not sure if it’s true, but I love the 3.91s in my car. Worth it!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
04-23-2018, 04:56 PM | #11 |
USA-1
Yep, diffs are the same!
04-23-2018, 07:30 PM | #12 |
Here is the 3.91 diff part # 22806794. Based on my google search it shows to be discontinued.
04-23-2018, 10:37 PM | #13 |
Drives: 2013 Camaro SS Join Date: Feb 2017
https://rover.ebay.com/rover/0/0/0?m...2F362289953734
When I searched ebay this came up |
04-24-2018, 11:26 AM | #14 | |
