04-21-2018, 06:47 PM | #1 |
Drives: N/A Join Date: Nov 2015
Mixing Run Flat with Non
So I happen to have a set of new OEM rear run flats. Since I'm looking to go wider I was thinking of using them on the front and buying wider ones for the rear 305/30-20. Unfortunately, the biggest Goodyear ROF are 275. What are your thoughts on running 275 run flats on the front and 305/30 nonflats on the rear?
04-21-2018, 09:43 PM | #2 |
Drives: 2017 Camaro 2SS Join Date: Jan 2018
+1
04-22-2018, 06:17 AM | #3 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
On the stock wheels? Think you need wider wheels if you wanna use wider tires.
04-22-2018, 09:59 AM | #4 |
I'll be going with 10s in the front and 11 in the back. The main concern is what will happen if I run the stock Goodyear 275 Rof in the front and Nitto regular in the back.
