09-11-2018, 04:48 PM | #1 |
Drives: 2013 Camaro Join Date: Aug 2018
Rough idle with no codes
Bought a 2013 V6 Camaro a few weeks ago and have noticed that is has a really rough idle, throttle response is fine and runs great above idle, it doesn't set any codes. It feels like a misfire but when I look at the misfire data on my scanner it doesn't show any. I cleaned the throttle body but didn't make any difference.
I was wondering if these cars have a problem with carbon buildup on the intake valves from the direct injection system like many other makes and models have ? I have googled it and haven't found any fixes. Has anyone had this problem and did you get a fix for it? |
09-11-2018, 05:47 PM | #2 |
This question Will prob require a little more info. How many miles? Any service records or maintenance performed? Have you checked plugs or wires?
09-11-2018, 06:27 PM | #3 | |
What I would like to know is if these cars have a tendency to run rough due to carbon buildup on the intake valves. The car has 130,000 miles on it so if a top tier fuel wasn't routinely being used it could possibly have dirty valves causing this issue. Some cars are more sensitive than others when it comes to dirty intake valves. |
09-12-2018, 11:51 AM | #4 |
May try posting in the v6 thread also. Was unaware it didnt use plug wires, but never even looked under the hood on the v6's.
09-12-2018, 12:10 PM | #5 | |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
09-12-2018, 12:26 PM | #6 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
09-12-2018, 03:26 PM | #7 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Bad engine mounts?
09-12-2018, 09:40 PM | #8 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Ghost Cam, Trifecta Tune
Turn your Cruise control on/off and see if the rough idle goes away off is rough idle on is smooth idle
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
