Old 11-28-2009, 07:28 PM   #1
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
How to Wire Footwell Lighting
I wanted to do this as cleanly as possible, so running a wire all the way from the dome light was right out. Let's dig in!
K9 is the BCM and X7 is the connector that has the dome light wire. K9 is just above the accelerator pedal and has 7 color-coded connectors on it. X7 is grey in color and so is the wire in position 1 (our target). I attached a t-tap for this connection. See first pic.
I mounted my light strips under the dash and oriented the wire-ends towards the console. You can pull back the sides of the console to give access to a nice channel. I taped the passenger side light wires to the end of a stick and used it to fish the wire to the driver's side. See second and third pic. Note the bolt with the yellow line by it in the third. This will be our grounding point.
I then spotted a slot that I pulled the driver's-side light wires through to better hide them. See the fourth pic.
I took the two black (negative) wires, cut them to a good length, stripped them, crimped on a spade/ring terminal, and attached it to that bolt mentioned earlier. See the fifth pic.
I attached the t-tap mating terminal to a fuse holder, connected this to the red (positive) wires, and plugged it in. I then tucked the wires in behind the console and generally spiffed up the wiring before I snapped the console side covers back into place.
All done! Enjoy your illuminated feet, as others have noted! See last pic.
TonyNo is offline   Reply With Quote
Old 11-28-2009, 10:46 PM   #2
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Awesome, thanks for the write up, this has been saved .
daphatgrant is offline   Reply With Quote
Old 11-29-2009, 12:52 AM   #3
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Yes, great writeup! Thanks.
One question, can you please explain this line: "I attached the t-tap mating terminal to a fuse holder, connected this to the red (positive) wires, and plugged it in"
So, the red wires come from the inverters and you attached your own fuse to that end and plugged that in the end of the T-Tap that's connected to X7?
Thanks
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-29-2009, 03:12 AM   #4
Thrasherman
Support the NRA
Thrasherman's Avatar
Drives: C6 Corvette Vert/08 Silverado Crew
thx
Currently looking for something..
13 Jeep JKU-lift, tires, rims, light bars, etc
12 Pruis V
08 Silverado CC LTZ
06 Corvette Convert-blower,cam,headers,wheels-
Thrasherman is offline   Reply With Quote
Old 11-29-2009, 09:34 AM   #5
TonyNo
TonyNo's Avatar
I didn't use CCFL's, but, essentially, yes.
Old 11-29-2009, 10:02 AM   #6
BlownSS
BlownSS's Avatar
just so I got this right, You tapped into the Grey wire under the dash on the Grey connector.......you tied the red (power wires) into that wire and used the black wires as grounds on either side of the dash underneath. And this makes it so the lights just come on with the dome light correct?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 11-29-2009, 10:13 AM   #7
TonyNo
TonyNo's Avatar
You got it!
Old 11-29-2009, 08:16 PM   #8
Jakefeb3
Drives: 2010 camaro 1ss
What wire do I use if I want them to slowly turn on like the dome does, but I want them to stay on with the rest of the ambient lighting? I dont want them to turn off when the dome goes off
Jakefeb3 is offline   Reply With Quote
Old 11-29-2009, 08:24 PM   #9
Jakefeb3
Please! Anyone? Is it the purple wires for the ambient lighting?
Old 11-29-2009, 08:34 PM   #10
TonyNo
TonyNo's Avatar
I don't have AL, so I can't comment on that.
Old 11-29-2009, 08:43 PM   #11
TonyNo
TonyNo's Avatar
Looking at the diagram (http://www.camaro5.com/forums/showpo...41&postcount=4), the purple wire after SRK/SRM (whatever that is) is what you want.
Old 11-29-2009, 09:12 PM   #12
Jakefeb3
I'm looking at the connectors right now; looks like there are 2 purple wires. 1 on the black connector, and 1 on the green. Any ideas?
Old 11-29-2009, 09:31 PM   #13
TonyNo
TonyNo's Avatar
Based on the diagram, you want the purple wire after the SRK/SRM, not the wire on the connector at the BCM.
Old 11-29-2009, 09:37 PM   #14
Jakefeb3
Oh boy, i wonder what the srk/srm is
Where to wire in ambient footwell lighting? cybercoaster Cosmetics and Lighting Modification Discussions 32 01-11-2016 11:08 AM
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 05:00 PM
AACStyle footwell lighting problem TRSS2 Camaro DIY & HOW-TO instructions & discussions 8 01-23-2010 06:41 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 09:32 PM
