09-15-2010, 06:33 PM | #225 | |
Another good location is the traction control switch.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
09-15-2010, 08:38 PM | #226 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
ok jus got the kit in from aac and im a little confused i plan on jus running it with the dome light wire (the gray one) so they fade on and off but anyways it came with 2 power inverters so heres my question do i jus run both inverters off off the same gray wire then ground? or do i only need one inverter?
09-15-2010, 08:46 PM | #227 |
and has anyone had a problem with kicking the lights under the footwell it seems like theyd be easy to break? but idk i havnt really got under there to look yet
09-15-2010, 08:52 PM | #228 |
My footwell lighting consists of using the ambient door lights in the stock holes, no way you can kick them if you do that.
09-17-2010, 02:59 PM | #229 |
How long were your wires for the light strips? mine (that came with the lights) are about 6" long and im guessing thats too short.. are they too short, and how would i go about getting wires?
-MRT V1.0, H&R Springs, Injen CAI |
09-17-2010, 03:09 PM | #230 |
Drives: 2013 ZL1-Victory Red-Auto Join Date: Mar 2010
The wires on mine were also short. I bought some auto wire at Autozone and spliced some extra length in. Use electrical tape to secure the connection.
09-17-2010, 03:17 PM | #231 |
ok thanks. How many wires did u end up with in the end? I have two right now, but im just not sure exactly how to wire it. Does one wire go from one light strip to another and then another wire from the light strip to the grey wire? if this is right, i then need another wire to ground it? sorry i have no knowledge in wiring at all
09-17-2010, 04:35 PM | #232 |
are yall usiing two converters for both tubes or jus running them both off of 1?
09-18-2010, 10:00 AM | #233 |
Drives: 2SS SIM Join Date: Apr 2009
i kicked mine and broke it now i have AAC's new color leds they seem to stay out of the way better
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland welcome home 1100 4-27-09 6000 6-27-09 yes i got to the dance late don't hate me |
09-18-2010, 10:11 AM | #234 |
Drives: '11 SIM 2ss/rs LS3 #13363 iom seats Join Date: May 2010
Ive tried several different options for footwells, including tube, individual LEDs, and led strips. BY FAR the best option for placement, light quality, and ease of installation has been the light strips. I used the red 12-led strips from xenithxenons, but I also tried the blue and the white but since I have the IOM interior, the red matched perfectly.
There is no worrying about kicking or breaking anything with these, and placement is by far the easiest since they are flexible and have 3m tape already applied to them. |
09-18-2010, 11:51 AM | #235 |
My car runs on acorns....
Drives: 2010 SS RS Inferno Orange Join Date: Feb 2010
I'm pretty happy with the abl colored led strip from aac.
09-18-2010, 11:52 PM | #236 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Foot Well LED supports
As luck would have it, I was doing some fix'er up jobs around the house and one of them was to install new floor transition mouldings on some of the room door thresholds. I went to the Home Depot and picked up this plastic channel that is used to hold down the "T" shaped piece of floor moulding.
After the job was done, I had some extra lengths of the plastic channel and I thought, "This would be perfect for holding the LED foot well light strips" (that I just received from AAC). Haven't installed the strips yet, but have a look at these pics. The strip fits perfectly within the channel and it will be easy to zap strap them on to the underside of the dash where there are convenient holes. The passenger side is especially helpful cause there isn't a good flat surface for the light strips to be glued to. The footwell strips have 3M double sided sticky on it. These plastic channels come in 36" lengths.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
09-19-2010, 07:37 AM | #237 |
Drives: Would only drive GM Join Date: Nov 2009
It just seems a shame that paying that much for such a beautiful car with such nice looking interior and GM was to cheap to put foot well lighting in them. Maybe in the future. Even my 2007 Canyon SLT came with foot well lighting.
09-19-2010, 03:11 PM | #238 |
so im using both inverters for the two footweel ccfl tubes from aac.....since im using both converters i will have to use two t taps to tap into the gray domelight wire this will work right?
Thread Tools | |
Similar Threads | ||||
Where to wire in ambient footwell lighting? | cybercoaster | Cosmetics and Lighting Modification Discussions | 32 | 01-11-2016 11:08 AM |
Anyone have the Footwell Lighting Kit Installed? | wildthing001967 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 12 | 07-03-2011 05:00 PM |
AACStyle footwell lighting problem | TRSS2 | Camaro DIY & HOW-TO instructions & discussions | 8 | 01-23-2010 06:41 PM |
footwell neon lighting. How to wire to have it come on the other ambient lighting? | Jakefeb3 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 11-22-2009 09:32 PM |
