12-31-2018, 07:49 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Anyone running a 6.0 iron truck short block?
I'm looking for an inexpensive alternative to a $5000 forged shortblock.
I've heard the iron 6.0 shortblocks can take a beating, but I'm reading online that the lq4/lq9 have cast pistons, and cast crank. Do any have forged assemblies? Is anyone pushing a stock 6.0 short block around the 1000 hp area with success? I'd like to pull my LS3 and keep it aside while I crank this ESS Supercharger up. If you have a big power budget build, I'd love to know what you're running. Thanks
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
12-31-2018, 08:56 AM | #2 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
LQ9 block, you can send it. Machine is out, to 408CI. Pistons rods etc. Ls3 heads and your good to go.
12-31-2018, 08:58 AM | #3 |
I think what you will find, is that there are those few individual cases (LS2 & LS3 blocks)where some guys have achieved 1K+ RWHP numbers on the stock rotating assembly, but those are the exceptions and not the 'rule'.
The cheapest alternative I can think of is just forging your LS3 block, probably in the neighborhood of ~$3K including machine work. Probably the most cost effective solution is just buy a forged short block from TSP or similar. |
12-31-2018, 09:02 AM | #4 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I will be using a stock long block ly6 this season while I build my 427. plan on stopping around 900whp with it
12-31-2018, 10:25 AM | #5 | ||
Ok, I see the ly6 is 9.6:1, but also still cast stuff. Any reason you chose that over the lq4 with 9.4:1? Is the compression the only difference between those 2?
12-31-2018, 10:44 AM | #6 |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
If you are swapping and using the stock crank I think you will run into problems since the crankshaft reluctor wheel in the LQ4/LQ9 is 24 X while our cars run the 58 X. I think Lingenfelter makes a box that will convert the 58 signal to 24, but not vice versa.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
12-31-2018, 10:51 AM | #7 |
correct, it's 58x but the ly6/l96 has gen 4 rods over the gen 3 press fit. along with slightly raised water jackets over the gen 3 block and a better casting
12-31-2018, 11:14 AM | #8 | |
I lived my early years doing exactly this (without the experimenting, boost, or intelligence ) because I could get junkyard SB 350's for $150. I must have went through at least 6 motors my senior year. I got really good at swapping those things out |
12-31-2018, 11:53 AM | #9 |
Drives: 14 and 15 SS's Join Date: Feb 2018
The GM iron blocks are a great alternative! Are you think just bone stock junkyard iron block or putting Pistons and rods in it? I think if you put Pistons and rods in the iron block, you will be in great shape.
Forging the LS3 block at those power levels is a bandaid. It's the block itself that is the weak link
Bolt-ons!
12-31-2018, 12:09 PM | #10 | |||
I'm tempted to just get a good running junkyard 6.0 and cram some boost into it. I've got research to do.
12-31-2018, 10:01 PM | #11 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
I run the LQ9 with a Whipple but I forged the bottom end completely. TS offers a great 408 short block. If your stroking go with the melling HV 296, and get the optional 58 RW at no cost. You’ll need to drill the block for accessory mounting. It’s a very solid package and if the right components are added you should be seeing north of 1000+ HP. I find this combination very reliable and have had zero issues other than the additional 80 lbs which I don’t even notice...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
12-31-2018, 10:11 PM | #12 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Just get a LSX376 crate. I've had one in my car for 6 years. 17 lbs boost and 750 whp.
01-01-2019, 10:37 AM | #13 |
Why would you do that a 5.3 junkyard motor can make that with no work and it’s $500 lol. Fail. TSP easy, if you want to put together a combo n make big power. Add some more cubes like I’ve ssid before makes it easier. Oh and on price, gotta Pat to play plain and simple.
01-01-2019, 10:48 AM | #14 | |
5.3 junkyard engine can do that with no machine work or changing internal parts. And it comes with a warranty from GM. Got it. |
