04-09-2020, 02:03 PM | #1 |
Drives: 2018 ZL1 1LE, 2014 ZL1 Join Date: Jul 2017
DRIVESHAFT REPLACEMENT? ALUMINUM OR STOCK?
I ended up tearing the boot of my driveshaft at COTA a few weeks back. Not sure how or what happened, but i am being told there are no boot repair kits for the ZL1 1LE driveshaft. So I might as well upgrade if I am replacing.
The car is strictly used on track for road course. Is the best option Aluminum from driveshaft shop? https://www.driveshaftshop.com/domes...nsmission-only Has anyone hear good or bad things about aluminum driveshafts on track? or should I try to find a stock replacement? |
04-09-2020, 02:07 PM | #2 |
Drives: 2019 Chevy Camaro ZL1 1LE Join Date: Nov 2019
I have an Aluminium one for my 240SX track car (300 whp) from them and it's awesome. Made the car more responsive.
The ZLE has twice the power, but should be fine if the build quality is the same. I planned on upgrading in a year or two. |
04-09-2020, 02:16 PM | #3 |
I probably should add my car will be around 700 whp when done..
04-09-2020, 02:18 PM | #4 |
You'll be fine. I've seen them on much higher HP cars and never personally knew anyone with an issue.
04-09-2020, 03:16 PM | #5 |
Drives: Grandad's C2 L89 Join Date: May 2017
For another $500 (if your finances allow), you might consider CF. Not a whole lot of weight savings but if durability is the issue, CF may be a viable route/consideration for you.
2018 ZL1 1LE sw/PDR
04-09-2020, 03:55 PM | #6 |
04-09-2020, 05:05 PM | #7 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
The GForce 3.5" aluminum one is ultra smooth and very nice. Two thumbs up so far on mine.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
04-10-2020, 10:13 AM | #8 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
This^ very pleased with my Gforce shaft. ~ 10k miles and several track days with no issues. I'm around 730whp so you should be fine.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
04-10-2020, 10:30 AM | #9 | |
04-10-2020, 12:21 PM | #10 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
I don't have personal experience with them, but when I was looking at driveshafts for my Z/28, I heard a LOT of bad feedback about DSS.
04-10-2020, 12:54 PM | #11 |
04-10-2020, 01:40 PM | #12 |
Not off hand, but I did weigh the new GForce vs the stock one and the GForce one was about 7 pounds lighter than the stock SS driveshaft. If you have a ZL1, the difference will be even more.
Tags |
camaro, driveshaft, zl1, zle |
