07-18-2020, 09:11 PM | #1 |
Drives: 2012 Camaro SS Convertible Join Date: Nov 2014
2020 - Best Brake Upgrade
Hey Guys,
I read a lot about brake upgrade kits for the Camaro SS. I Have a 2011 Convertible Automatic running 20" Z28 spec wheels with a Tune, Headers, Cat Delete, CAI, Catback, Throttle body, Sway Bars, Poly Bushings, Strut Brace etc. I am considering either the Genuine ZL1 Front & Rear Upgrade package (a little steep) or the CTS-V Upgrade Kit (Who all offers this currently??) I would prefer to stick with OEM/Brembo options as I dont wan't to experiment with anything non OEM with brakes! |
07-18-2020, 10:11 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Look into the C7 Corvette Z06/Grand Sport caliper they are cheaper than the ZL1 and also come with vented pistons. Now rotors will be a issue unless you can source a set of somebodies junk rotors and use a set of KNS/DBA rotors for the Z06/GS. Or find a set of OEM ZL1’s about 300’ish per rotor. Also there’s a set of Brembo rotors for less than 175.
Caliper; https://www.rockauto.com/en/catalog/...b,caliper,1704 Rotor; https://www.rockauto.com/en/catalog/...hub,rotor,1896
Orange Krush II
07-23-2020, 08:30 AM | #3 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
You can get 6 piston CTSV2 calipers for under $300.00 each from Auto Zone 249.00 plus 47.00 core charge
You also get your choice of 3 colors Silver Yellow or Red Rotors are about 75 bucks each You do not need rear brakes as your 4 piston rears are the same as a ZL1s
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
07-23-2020, 10:17 AM | #4 |
I didn’t know that AutoZone had the CTS-V caliper good info there!!
Orange Krush II
05-16-2024, 06:15 AM | #5 |
Hi All,
Can anyone guide where is the best place to buy a full brake upgrade kit as of 2024? I am looking for Z06 upgrade. Thanks, |
