09-23-2020, 09:30 PM | #1 |
Drives: 1LE Join Date: Sep 2017
Absolute lightest available 18" rims?
Much appreciated!
09-24-2020, 10:56 AM | #2 |
Drives: 2016 1ss camaro Join Date: Feb 2016
09-25-2020, 01:04 PM | #3 |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
Apex FL-5 are very light, 18x10 weighs 20.5#, and 18x10.5 weighs 21#. https://www.apexraceparts.com/our-wh...ution-fl5.html
The 18x10.5 may be the best choice, so that you get more performance out of 275-305 width tires. I have a set of the 18x10 on my LS 1LE (FE3 suspension), and I really like them. With a 5mm spacer, they clear my strut. Note, this is a BMW wheel, so I use plastic rings to make them hubcentric. (I am about to fix this with some custom 12 mm bolt-on spacers that will have BMW hub spacing.) |
09-25-2020, 07:49 PM | #4 |
Drives: 1985 Oldsmobuick Join Date: Oct 2012
Obviously HRE and Forgeline make some pretty light wheels.
I don't have any experience with them, but Litespeed offers all of their wheels in forged magnesium as an option: https://www.litespeedracing.com/technology |
09-25-2020, 10:19 PM | #5 |
Thanks!!!!!!!
09-26-2020, 07:14 PM | #6 |
Drives: Honda S2000 Join Date: May 2019
I have Apex 18x10s they do feel quite light. They aren't crazy expensive either
11-08-2020, 12:55 PM | #7 |
Drives: Chevrolet Camaro SS Join Date: Apr 2019
18x10.5” Superspeed RF05RR = 19.8lbs
11-08-2020, 04:52 PM | #8 |
Drives: 2017 Camaro 1SS Join Date: Nov 2018
18x10.5 +27 TSW Bathurst is 20 lbs. and reasonably priced. You will need a 10 mm spacer and extended studs to clear the front strut though.
11-08-2020, 07:31 PM | #9 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
you want light and strong. Forgeline or bc forged.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
11-09-2020, 10:51 PM | #10 |
Thanks for replying ya"ll
11-10-2020, 06:24 PM | #11 |
Drives: 1LEs Join Date: May 2009
FINSPEED in Austin will make whatever you need including non-normal widths and offsets. Not cheap, but, like your other toys, you asked for the lightest not the cheapest.
https://finspeed.com/ |
11-10-2020, 07:15 PM | #12 | |
Heater box will be gone too...25lbs. A little bit more work and i believe I can chop a total |
