Old 03-08-2021, 12:39 PM   #1
Level300
Drives: 2015 Black rs/ss/1le
Oil pan removal using engine hoist...
Hi,
During my cam swap, I plan on using an engine hoist to lift the engine so I can remove the oil pan (putting in baffles).. Assuming the car is on jack stands and the heads are off, is there enough clearance before I hit the firewall to remove the oil pan or do I still need to drop the cradle?
Thanks
Level300 is offline   Reply With Quote
Old 03-08-2021, 04:56 PM   #2
gsxrturbo
Drives: 2010 ss
i would say no.i cut and welded flanges,so now i can unbolt my cross member.there isnt much room to lift the engine at all.maybe someone will chime in that has other ideas.
gsxrturbo is offline   Reply With Quote
Old 03-08-2021, 06:30 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Never gonna happen with the trans connected. Your best bet is the crossmember mod...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 03-15-2021, 05:36 PM   #4
Level300
As much as id love to do the flange mod, I don’t want to go that route. I don’t plan on doing this again. I’m getting too old for this LOL.
