08-14-2021, 03:28 PM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
OEM vs. High Flow Cats
Maybe a trivial question
But what will be the difference between OEM and HF Cats in terms of emissions? I was looking for something, but mostly the answer "I'm from Florida, we don't have emissions" or "how many horses will add HF Cats". Here in Europe, the emission frenzy is in full swing, and if I need to return the stock tune, I would like to know what result awaits me. I don't like the idea that I will have to change every 2 years OEM exhaust manifold with cats for emission check .
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
08-14-2021, 04:47 PM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
On a more serious note, I recall some threads where this was discussed over fear of failing inspection and IIRC, the consensus was that they allow more pollutants than stock cats, but perhaps not enough to make you fail. Other options might be some kind of cutout set up or run it on E85 if you have that over there. Alcohol burns much cleaner.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
08-14-2021, 09:16 PM | #3 |
Started#gottalovethatblue
The last two places I've lived have had emissions and passed with long tube headers and high flow cats. Unless you have ridiculous laws like California that require you to not have long tube headers, get some long tube headers with high flow cats tube your car, and you'll be fine. Best of luck on your situation!
08-15-2021, 02:55 AM | #4 | |
So far, I am meeting the emissions for my country. But emissions for the LS3 Camro are slightly higher than normal. So it was always somehow solved. Sure ... Ecology must be taken into account. A car that smokes like a dug stove is probably not okay. But panicking the grams of exhaust fumes at a car that drives a few hundred miles a year seems a little off. I don't have much good experience with E85. I tried the conversion on the other car and I couldn't reconcile it well. Correctly, the injection cycle should be extended by 30%. But the engine was still missing. He stopped omitting up to 1%. But what is one percent of 30. I saw a couple of destroyed engines from incorrect E85 settings. So I'm leaving this idea in the background for now.
08-15-2021, 03:15 AM | #5 | |
I have Stainless Power long tubes and Stainless Power HF cats. The condition of the emission control is that I must not have any CEL and no warning light must be on. That's why I have an "emission" tune created in the backup. It's basically an OEM tune, but the rear O2 sensors are disconnected so that I don't see CEL. So I would like to know what will happen if this situation occurs and I would record an OEM tune for HF cats. If you say it's going to be okay, it calmed me down a bit.
08-15-2021, 01:16 PM | #6 | |
They also have devices that produce a dummy signal for the rear O2s as well as extension that HFCs not throw codes. Like yours, mine are turned off, so I can't speak to how well they might work.
08-15-2021, 02:54 PM | #7 | |
08-15-2021, 03:21 PM | #8 | |
But as I wrote. The engine did not run well. So I left this idea. I won't lie that I wouldn't like the E85 conversion. They say it works wonders with the car. But when I asked my tuner about the Camaro, it is said that it does not convert to the E85. And I don't dare do it myself.
08-15-2021, 03:30 PM | #9 | |
Inserts the sensor into the exhaust and maintain the engine speed at 2800 rpm. And you have to fit on the scale. I didn't interfere with the engine. I did things around. Long tubes, cats, CAI and ported throttle body and tune. So when I return the original tune, the engine should be back in factory mode. But the question is how much it will affect HF Cats. But I also think that if there is a difference, so small.
08-15-2021, 06:28 PM | #10 | |
I'd be careful with going back to a stock tune though. With long tube headers they will throw a code.
08-16-2021, 07:05 AM | #11 | |
The car connects to the OBD port, inserts a probe into the exhaust and the test takes place on a static car. I assume you'll have it anyway. The test itself takes a few seconds. The only thing that could light up is the CEL of the rear o2 sensors. And these are off. So that should be fine.
08-16-2021, 07:34 PM | #12 |
Drives: 2012 2ss stick. Boosted 45th! Join Date: Oct 2020
Here in Kommiefornia we are officially screwed. We can’t really change anything cat forward except some CARB #’d shorty headers. Can’t touch the cats at all. The difference as far as emissions actual data? No clue. But I do believe most HF cats are “spun metallic” and stock are standard platinum style cats. Sorry, don’t know the technical name. On my GTO’s the HF cats were a big performance gain, for the money.
45th Anniversary.stick. Boosted!
08-16-2021, 08:46 PM | #13 | |
08-17-2021, 01:00 AM | #14 | |
I really don't ride that. I'm usually below 2,000 rpm. But looking for reason in the European Parliament is like looking for a needle in a haystack.
