09-17-2021, 06:29 PM | #1 |
Drives: 1987 Camaro Join Date: Apr 2019
My 700r4 won't shift into 4th gear
Normal driving it is fine shift at about 35 mph but put down the accelerator to the floor and it won't shift into 4th all the rest of the gears are fine/. 1987 Camaro 355 built.
09-18-2021, 10:04 AM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
You’ll have a better shot if you go to thirdgen.org
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
09-18-2021, 01:09 PM | #3 |
09-22-2021, 06:31 PM | #4 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
Had one of these a LONG time ago. Same issue.
It needed a special valve in the tranny to keep it in 4th at WOT I think it was.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
