Old 01-01-2022, 01:34 PM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
ZL1 Front Tow Hook issue
OK, so I think I've read about all I can stand about tow hooks. My issue seems to be unique so hopefully a Z owner on here has had the same experience and figured a solution.
The short explanation is this.
My 2014 ZL1 doesnt have a provision for a front tow hook at all, period.
No trap door thingy in the black grill and no threaded hole in the crash bar under the cover.
I bought a crash bar with the tow hook hole and I would have to punch a hole in the painted portion of the cover to make it work...not an option.
I looked on ZL1 Addons sight and don't see how that setup will work on my OEM crash bar because I never found his install instructions.
I wrote ZL1 Addons and await an answer.
Does anyone have answers?
Thanks in advance
Mark
FasNuf is offline   Reply With Quote
Old 01-01-2022, 02:33 PM   #2
Hoosierjta
Drives: 2015 Camaro Zl1
I have a 2015 ZL1. I had the same issue. Wanted something there for occasional track days. I ended up buying the (what I believe was the GT4 tow hook--whatever they called the 'L" type bracket) and drilled holes in stock crash bar to mount it. I bought the black one. It pokes out through the opening in stock ZL1 lower grill. Obviously it's not temporary, but not overly noticeable if that is a concern. I can't attest to durability as I haven't had to use it yet. Hope that helps.
Hoosierjta is offline   Reply With Quote
Old 01-01-2022, 02:34 PM   #3
HDRDTD
Z/28's had the tow hook, but I'm not sure about the ZL1's having them.
My 2013 ZL1 did not come with a tow hook nor the option to have one from the factory.
Old 01-01-2022, 04:05 PM   #4
FasNuf
FasNuf's Avatar
Where did you buy it?
Old 01-01-2022, 04:30 PM   #5
FasNuf
FasNuf's Avatar
I did see this on SMGspeed.com
https://smgspeed.com/product/5th-gen...-bar-tow-loop/
Old 01-01-2022, 09:56 PM   #6
Hoosierjta
I’ve searched and unfortunately can’t find where I ordered it from. The link you have is not the one I used though. Mine is “L” shaped and goes under and up the backside of the crash bar. I’ll keep looking and if I find my order history, I’ll let you know. Sorry.
Old 01-01-2022, 10:20 PM   #7
FasNuf
FasNuf's Avatar
No worries. Yea, going up the back would be a stronger design. I might just make my own and have a local shop burn it out on their table. Maybe I can mock it up with balsa wood first. This gives me ideas for a new video too. I could slot the holes in the vertical portion slightly to make it a better fit before tightening.
Thanks for the ideas!
Old 01-01-2022, 10:41 PM   #8
diddies
Drives: 2013 ZL1
Thanks in advance
Mark
If you have changed the crash bar, the ZL1 Addons will not work per their instructions. I would believe you would have to weld their piece onto your crashbar.
diddies is offline   Reply With Quote
Old 01-01-2022, 11:38 PM   #9
FasNuf
FasNuf's Avatar
I have both the original and an aftermarket. They look identical except the threaded hole. I never saw their instructions. Do you have a file to share?
Old 01-01-2022, 11:41 PM   #10
Vicster
Vicster's Avatar
Drives: 13' ZL1
Front Tow
Made my own, install with grade 8 bolts, made inner bumper supports from PVC pipe.
Vicster is offline   Reply With Quote
Old 01-01-2022, 11:44 PM   #11
FasNuf
FasNuf's Avatar
I think I’ll go this route too Vic ^^^^
Old 01-01-2022, 11:58 PM   #12
Vicster
Vicster's Avatar
Drives: 13' ZL1
Hey Bud
Pics are from my first ZL1, did not take any with the new one.
I was not able to bend the 1/4" plate, had to take it to a welding shop.
Old 01-02-2022, 12:32 AM   #13
FasNuf
FasNuf's Avatar
We have a brake at work I could probably use but they won’t allow personal use of the burn table. There’s an outfit in town that can do the burn out
Old 01-02-2022, 10:35 AM   #14
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Did not realize that adding a front tow hook was this much if a pain but it is worth it . I think I’ll do this mod aswell . Thanks fastenuf for bringing this up sir .
Risingson05 is offline   Reply With Quote
