01-13-2022, 10:55 PM | #1 |
Drives: 2016 2SS Red Hot Join Date: Dec 2015
Did my alternator go bad?
Recently my Camaro was completely dead after trying to turn it on. Had to jump start it a couple times. Took the battery to AutoZone and they tested it and they said it was only holding 5 volts. Bought a new one, it was time since it has been at least 4 years and also it spent several months parked where I only drove it once every few weeks. Worked fine for the next 3-4 days until today it was completely dead again. I had to jump start it. Also had the check engine light on and a new icon where the battery voltage should be on the dashboard. Looks sort of like an alternator to me with the arrow pointing to -15. It was only there for a few seconds before it went back to the battery voltage icon. Anyone know what it means?
https://i.imgur.com/l4BEhD1.jpeg
2SS Red Hot 6 Speed, NPP, MRC, 5 sploke black low-gloss, glow-tie
01-13-2022, 11:00 PM | #2 |
In addition, I just discovered a water leak in the trunk. It was at least 2 inches high and got to the fuses back there because the screen is completely black when I drive and the signals do not make the clicking noise. Thats a whole other issue to tackle later, but could this have something to do with it? The trunk is very humid right now and the old battery I took off was soaked with humidity. Planning to dry it out asap with a blow dyer or something.
01-14-2022, 05:34 AM | #3 | ||
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Dead batteries and low voltages do all sorts of weird things to our cars, including false positive CELs. Clear the CEL. If it returns, get it checked out. Quote:
Your alternator is probably fine. |
Tags |
alternator, battery, dead |
