01-23-2022, 10:16 PM | #1 |
CFD's removeable crossmember fabrication
OK, I'm just a guy in his garage so I'm sure I didn't do this perfectly, but it seems to work great and super tight. Thanks George.
Shameless self promoting video... https://youtu.be/2iqekORDMu8 . . . . . .
01-24-2022, 09:25 AM | #2 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Psssss. You did awesome like always . Better than I did lol , had to grind and re weld tab cause of alittle gap that bugged me
01-24-2022, 09:26 AM | #3 |
Drives: 2013 L99 Join Date: Jan 2019
Very well done
01-24-2022, 12:03 PM | #4 |
Thank you guys
01-24-2022, 01:12 PM | #5 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
Looks great! I just had mine installed this past Friday. Now time to remove the oil pan and replace that oil pan gasket. I have everything out, just need to wiggle it out, ugh!
Allen
2011 Camaro 2SS/RS |
01-24-2022, 02:04 PM | #6 |
great job! Ive wondered about doing this as well.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
01-24-2022, 02:08 PM | #7 |
My pan was still hard to get out but much easier without the crossmember. Still had to shift the rack forward and loosen the sway bar mounts to be able to move the rack far enough forward. The pickup tube hangs in there too.
01-24-2022, 03:31 PM | #8 |
Been meaning to ask in your vids I noticed you had like 3 55gal drums that are blue . Is that e-85?
01-24-2022, 04:20 PM | #9 |
GREAT job & video ...thanks for taking the time to make it! I wonder how many others who did this also welded the inside of the flange top to the crossmember stub to compensate for not being able to weld the outside flange top to the stub?
01-24-2022, 05:12 PM | #10 |
Yea, 2 of them are basically full, the other is a transfer drum to get the full barrels to the ground from the bed of the truck. They had ispropyl alcohol originally in them.
01-24-2022, 05:17 PM | #11 | |
I would think all if they read CFD's instructions.
09-17-2022, 08:58 PM | #12 |
Drives: Chevrolet Camaro SS Join Date: Jul 2021
Best version of the mod I've seen. Now come do mine!!
09-18-2022, 12:35 AM | #13 |
Thank you sir!
03-07-2023, 01:55 PM | #14 |
Anyone happen to know someone in the DFW area who could do the cut and weld for me after I get these flanges?
